Choosing a CR
Old Dec 25, 2011 | 07:46 PM
  #26
Turbo-LS's Avatar
Default Re: Choosing a CR
Originally Posted by ALL M0T0R
I personally have tuned quite a few setups that are running stock sleeved setups running 18-20psi of boost @ 8:8 or 9:1 CR , the car has no *** until 6k. I'll leave it at that.
Old Dec 27, 2011 | 06:42 PM
  #27
Tony the Tiger's Avatar
Originally Posted by Chak
Tony what do you recommend for the 94 oct up here in ontario, on stock sleves and lower boost levels <20
Let me know the power goals, and your intended usage... Lots of ways to determine this, from turbo size, manifold choice, bigger cams not, etc... Bigger turbo allows more room for safe power, so PM me with these details and I will recommend you a compression to go with
Originally Posted by komat
i have to call bs on 205 neogen hooking on WOT 3rd gear at 550whp... unless this thing makes no tq
You got it half correct, because torque is a major reason why a lot of these turbo Hondas can't hook worth sh*t.
But at the same time, traction is so different from car to car. At one point, my Integra had lots of trouble hooking 560 WHP with an ITR transmission and LSD, no traction bar, but Yoko A048 205-50-15. The car was crap, and I figured that's the most I can ever make with this car.
A simple LSD upgrade, Fullrace traction bar and PIC coilovers allowed me to hook up to 650 WHP clean on a nice summer day. Everything was identical, same engine/turbo/power level, same tires, same gear ratios. I went with a Quaife/Wavetrac LSD + traction bar was basically the reason why I ended up with 650+ WHP right now. I don't make the power unless I can enjoy it...lol
Such basic upgrades can make such a drastic difference, so I don't even bother doubting people anymore. Tire size is such a miniscule factor when regarding traction at rolling speeds.
Old Dec 27, 2011 | 06:48 PM
  #28
gringotegra's Avatar
How the power comes on, weight at each wheel (corner balancing), tires ETC.... the road you are on, temperature so many factors....
I have no quafe/lsd or traction bars. Just a well setup car
Old Dec 28, 2011 | 04:08 AM
  #29
DDTECH's Avatar
I believe it..
Just believe you blow tires off doesn't mean your car is fast.. i hate this common anology. A properly aligned, wheel/tire setup, and suspension setup will hook very well.
Old Dec 28, 2011 | 07:48 AM
  #30
komat's Avatar
yea but the nitto gen tires arnt really that sticky. i got a proper aligntment and suspension except for a traction bar. the neogen wants to break loose at 280tq on 3rd gears with a gsr non lsd tranny.
Old Dec 28, 2011 | 10:34 AM
  #31
What Chassis?
Not sure, i can just say that i set the car up to be a street tire car. Not many people dip into the 11's on a 205 non drag radial street tire in a FWD car... It is within 5lbs on the 2 front tires with me in the car..
unknow
Sep 14, 2010 05:49 AM
bunnyx
Jun 14, 2010 11:07 AM
swapdohc
Jul 14, 2005 03:54 PM
atmo_monster
Apr 30, 2003 02:34 PM
