Chipped Ecu (difference in hondata, Neptune, uberdata etc..)????
Old Apr 18, 2005 | 06:36 PM
iBrandon's Avatar
Default Chipped Ecu (difference in hondata, Neptune, uberdata etc..)????
I been reading up extensively on tuning and ecu chipping...my question is because i didnt run across it while researching is...Can you use the same Chipped ecu for lets say Uberdata and use it on hondata for example or do you have to modify it? If not what minor differences are there b/w chipped ecu's for crome, uberdata, neptune, and hondata (besides the blue box )
I had a freind send in his ecu which was chipped for hondata to convert to neptune? so i just wondering what adjustments to they make? Thanks
Old Apr 18, 2005 | 06:38 PM
braintree's Avatar
Default Re: Chipped Ecu (difference in hondata, Neptune, uberdata etc..)???? (Shy Gsr)
I spoke with superdave from whip factory and he told me yes. I had one chipped for hondata and I was told that I can use it for neptune.
Old Apr 18, 2005 | 06:40 PM
91dxcrx's Avatar
yes you can use the same ecu
iBrandon's Avatar
Default Re: Chipped Ecu (braintree)
Ooo ic..so no change necessary then..i wonder why they told him to send in his ecu chip...Hmm ??
Old Apr 18, 2005 | 07:16 PM
Blown90hatcH's Avatar
You will need to add the 4 pin interface wire for the Hondata cable. That is not needed for some of the other softwares.
Old Apr 18, 2005 | 07:31 PM
93turbo16's Avatar
ANy OBD1 honda ecu that has been chipped can run any program that is made for it. Only difference is if the 4-pin header is required.
Old Apr 18, 2005 | 07:51 PM
iBrandon's Avatar
Default Re: (93turbo16)
but for data loggin with any prog you need the 4 pin correct??
Old Apr 18, 2005 | 07:58 PM
HRTuning's Avatar
Default Re: (Shy Gsr)
Yes, they also make sure it's setup for duplex communications... I'm sure there's a reason he sent it in...
Old Apr 18, 2005 | 08:01 PM
93turbo16's Avatar
Yep, just like hondata S100.
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
inh
Apr 19, 2006 08:30 AM
95turbogsr
Jun 26, 2005 09:17 AM
B16Civic93
Feb 17, 2005 08:54 AM
99B16Si
Sep 29, 2004 06:53 AM
