checking timing
Old Mar 31, 2004 | 11:42 AM
Lei Siew Long's Avatar
Default checking timing
my timing is jumpy and i can't get a definitive number because the white mark on the crank pulley doesn't line up with the pointer on the timing belt cover. it would line up to the pointer for a quick moment and fluctuate back and forth.
i'm running JG turbo camshafts on my LS engine, would this be a factor with this timing issue?
i'm using the Craftsman advanced timing gun with the dial.
Old Mar 31, 2004 | 11:46 AM
Nextelbuddy's Avatar
Default Re: checking timing (Hatch4urSnatch)
when you shoot the timing light at the crank pully you are supposed to look for the red mark that has the 2 marks above and below it.. i have never seen the white mark appear with a timing light only the red one..
Old Mar 31, 2004 | 11:51 AM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch &raquo;</TD></TR><TR><TD CLASS="quote">my timing is jumpy and i can't get a definitive number because the white mark on the crank pulley doesn't line up with the pointer on the timing belt cover. it would line up to the pointer for a quick moment and fluctuate back and forth.
i'm using the Craftsman advanced timing gun with the dial. </TD></TR></TABLE>
make sure you jump your ECU.
it will smooth it out
Old Mar 31, 2004 | 11:52 AM
Mase's Avatar
Default Re: checking timing (Mase)
also the reason u see the white mark is because your shooting 16 degrees of advance
nextelbuddy isnt using an advance gun, thus thats why u are at the red.
Old Mar 31, 2004 | 11:56 AM
my bad lol i didnt see the last part of his post... i learn something new every day.
i didnt jump my ecu when i set my timing on the dizzy when i used a timinglight.. would reseting the ECU take care of me not jumping it at the time?
Old Mar 31, 2004 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
it will smooth it out</TD></TR></TABLE>
yes, the ECU was jumped prior to checking the timing.
thanks for the suggestion though.
JDMtype Eg6
Sep 3, 2008 05:14 AM
NSfit
10
Nov 14, 2006 11:17 AM
Inspector Gadget
Aug 27, 2004 05:11 PM
slowd16z6
Mar 13, 2004 02:20 PM
JONBLAZE55555
Nov 27, 2003 12:46 PM
