Check valves to fool the ECU
Old Sep 3, 2001 | 08:18 AM
Teluan's Avatar
New User
Default Check valves to fool the ECU
I read on this board that if I am going to keep my 1991 CRX si ECU that I will need along with a better fuel pump, fuel injectors, and FMU, a check valve to fool the ECU when boosting.
I have two question about this.
1. If I do not have a check valve and I am boosting will the ECU freak out and cause erratic engine behavior?
2. Where do get check valves?
Thanks
[Modified by Teluan, 5:39 PM 9/3/2001]
Old Sep 3, 2001 | 08:25 AM
98Psi ITR's Avatar
Default Re: Check valves to fool the ECU (Teluan)
I think you can check valves almost anywhere like a Napa. I got a few from Toyota.
Old Sep 3, 2001 | 09:28 AM
redline's Avatar
Default Re: Check valves to fool the ECU (98Psi ITR)
The check valve does not allow the ECU to see boost from the map sensor. Buy a missing link metal check valve.
You will throw a code and the ECU will go into limp mode if it sees boost.
k
Old Sep 3, 2001 | 09:40 AM
VTC_CiViC's Avatar
Default Re: Check valves to fool the ECU (redline)
Buy yourself a "Missing link" MAP sensor boost bleeder. Act like a check valve, looks alot more "factory-ish" than a bunch of check valves hanging off the MAP sensor.
Old Sep 3, 2001 | 11:23 AM
veejay's Avatar
New User
Default Re: Check valves to fool the ECU (VTC_CiViC)
check valves are one way valves used to block the positive pressure going into the MAP sensor. what you want is a check valve before the map sensor that will block boost pressure... and another checkvalve to bleed the boost pressure. i used check valves for an aquarium for a while and the setup I had worked well. I also used a brass tee fitting to allow manifold pressure to be distributed to BOV, boost gauge, etc. missing link would be best, but if you're a cheapy then the fishtank c.valves will work.
Old Sep 3, 2001 | 07:29 PM
Pritos's Avatar
New User
I used these large check valves for domestics.
Echlin from NAPA part number 2-970.
90AcuraIntegra04
Jan 31, 2006 05:50 PM
Johnny_Rocket
Apr 11, 2005 12:35 AM
wanttorace
Jun 11, 2003 06:55 AM
turbotec
Feb 26, 2002 03:34 PM
