check engine light...help please!
hey guys i ran the search already n one of the search findings helped...but i was driving to the mall today and my check engine light just came on...the car seems to be running the same...jus wish that little annoying light would go away...should i disconnect the battery then reconnect it to reset the ecu? thats what my shop told me to do but i figured id ask on the board as well cuz u guys know lots of stuff...please help thanks...oh yeah...h23 prelude turbo running at 5lbs of boost...if that helps any...
it will most likely turn on again...but try that. To help us what kind of fuel management are you using? are you on stock ecu or standalone?
12 1 im running rich as all hell...im pretty sure it is unless my shop changed it to a lower ratio...ill double check tomorrow but pretty sure its 12 1 and im using the stock ecu
rhdins
Jun 11, 2008 10:13 AM
Smashback
Feb 21, 2002 07:13 PM
