check engine light...help please!
Old Sep 12, 2002 | 07:28 PM
hksturbolude's Avatar
Default check engine light...help please!
hey guys i ran the search already n one of the search findings helped...but i was driving to the mall today and my check engine light just came on...the car seems to be running the same...jus wish that little annoying light would go away...should i disconnect the battery then reconnect it to reset the ecu? thats what my shop told me to do but i figured id ask on the board as well cuz u guys know lots of stuff...please help thanks...oh yeah...h23 prelude turbo running at 5lbs of boost...if that helps any...
Old Sep 12, 2002 | 07:30 PM
CzanSOHC's Avatar
Default Re: check engine light...help please! (hksturbolude)
reset it first....see if that does anything....what's your code?
Old Sep 12, 2002 | 07:33 PM
Default Re: check engine light...help please! (CzanSOHC)
i dunno i havent checked the code yet...should i jus reset it then see if it turns on again?
Old Sep 12, 2002 | 07:36 PM
LudEcrous's Avatar
it will most likely turn on again...but try that. To help us what kind of fuel management are you using? are you on stock ecu or standalone?
CzanSOHC's Avatar
yea. try to reset...then check your code if it stays on.
Old Sep 12, 2002 | 07:38 PM
ok thanks...im running 350cc rc injectors, vortech fmu, aem fpr, and a walbro intake fuel pump
Old Sep 12, 2002 | 07:42 PM
CzanSOHC's Avatar
what disk w/ the FMU? 8:1?
Old Sep 12, 2002 | 07:44 PM
12 1 im running rich as all hell...im pretty sure it is unless my shop changed it to a lower ratio...ill double check tomorrow but pretty sure its 12 1 and im using the stock ecu
Old Sep 12, 2002 | 09:33 PM
CzanSOHC's Avatar
i would at least get 10:1 i mean...350cc injecotrs w/ 12:1 equals SUPER rich.
Old Sep 12, 2002 | 10:18 PM
98Psi ITR's Avatar
Reset light. Comes on again, check CEL number. It doesn't matter if you have a fricking jet turbo the computer doesn't care.
rhdins
Jun 11, 2008 10:13 AM
huntarrr
Sep 24, 2005 11:46 AM
CWBETB
10
May 29, 2003 10:16 AM
sneakypete
Sep 2, 2002 07:31 PM
Smashback
Feb 21, 2002 07:13 PM
