Check Engine light help needed ASAP
Old Jun 5, 2003 | 01:39 PM
420aNT's Avatar
Default Check Engine light help needed ASAP
My damn car will not rev past 2000rpm. I checked the ecu for codes and I am not sure if I am reading them correctly. I think it is either a code 5-10-or 15. I think I am getting a code 15 though. What can this be. My car is running hondata S100 w/boost and 780cc injectors. The car is buring gas like mad and blowing black smoke like crazy. Someone help me out ASAP. I already tried a new map sensor but it made no difference. The car is an 2001 GSR with a fully built motor.
Old Jun 15, 2003 | 08:45 AM
turbojdm521's Avatar
Default Re: Check Engine light help needed ASAP (18gTeg)
do you have to turn your engine on for the light to blink??
Modified by turbojdm521 at 6:16 PM 6/15/2003
Old Jun 15, 2003 | 09:38 AM
len's Avatar
len
How to read your CEL.
Short the SCS connector located on the passenger side right above the ECU.
You can do this with your own tools or use Honda Part 07PAZ-0010100.
Turn the key to the on position.
The CEL should blink.
Long Blinks are the first digit.
Short Blinks are the 2nd digit.
For instance 4 long blinks and 2 short blinks would be a code 42.
Old Apr 5, 2010 | 05:55 PM
Flat92sdan's Avatar
the codes i got were for the map sensor and tps i have same problem lemme know how it goes
Old Jul 11, 2013 | 12:37 PM
mattfiller's Avatar
As long as your own tool is insulated, and preferably a connector that fits, not a paper clip. Think about it. Do you really want to take a 3-inch piece of metal into a plush, carpeted area with few grounds, and connect it to the heart of your car's computer? On a dry day, you may destroy the computer instead of checking the error code. If you must use a paper clip, at least get a piece of heat shrink tubing, cut it about an inch shorter than the paper clip, center it on the clip, and light a match or lighter to shrink it. Or better yet, just shell out the 4 bucks for the 07PAZ-0010100!
Last edited by mattfiller; Jul 11, 2013 at 01:20 PM. Reason: Remove non-working icon url
Old Jul 11, 2013 | 12:52 PM
Turbo-LS's Avatar
Switch the plugs around sounds like you have them crossed which would throw both of those codes
Old Jul 11, 2013 | 02:19 PM
SiRCiviC94's Avatar
^ happens too often lol
Old Jul 11, 2013 | 02:58 PM
Turbo-LS's Avatar
I've done it at least half a dozen times lol. Speaking of which I'm going to mark mine so I don't so it again
Old Jul 12, 2013 | 03:12 AM
wantboost's Avatar
Who is Mr Robot?
They share the same plug and are in similar locations on the harness. It's very easy to get them mixed up of you don't know the wiring colors for each sensor or don't have the service manual
Everyone has done it more than once, I know I have. It's a fairly common mistake
Swap them around and see what happens
Old Jul 12, 2013 | 03:14 AM
grumblemarc's Avatar
The Grumpiest
10 year old thread. I hope the OP figured it out by now.
Old Jul 12, 2013 | 03:21 AM
wantboost's Avatar
Who is Mr Robot?
Ugh I got trolled
Why do people bump ancient threads?
Old Jul 12, 2013 | 05:01 AM
Turbo-LS's Avatar
Ugh damnit again ! Yeah idk why people bump old crusty dead threads. Let them die !!!!!!!!
Tasp72
Feb 14, 2016 04:28 AM
Darth CRX
Apr 29, 2014 07:33 AM
hondaxfresh7192
10
Mar 18, 2012 12:54 PM
oneoffaccord
Sep 9, 2006 09:21 AM
420aNT
Jun 6, 2003 07:05 AM
