Chase For 600HP
Old May 19, 2011 | 05:37 AM
JDM@sF*ck's Avatar
Default Chase For 600HP
This is currently the setting up im goin to hit my hp goal of 600hp in my GSR-T EJ8, This build will be a lil slow considering im a student at Wyotech at Blairsville, PA and money is a little tight. Im hoping to have this build done by the end of summer(September). Im tearing my block down friday afternoon as soon i get home from school. I will be Dropping it off saturday morning to the machine shop (Jim Justice Racing Engines) In Winchester, VA. If you view this post please bump and let me knw what your imput is.
Bottom End
• 83mm Bore
• 83mm Darton Sleeves
• Cp Pistons 9.0:1
• Manley Turbo Tuff Rods
• ACL Race Bearings
• Decked
• Crank Balanced And Knife Edged
• Blue Printed
Head
• Super Tech Valves
• Super Tech Dual Valve Springs
• Super Tech Retainers
• ARP Head Studs
• Bisimoto 83mm 5 Layer Head Gasket
• 3 Angle Valve Job
• Type R Cams
• Skunk 2 Cam Gears
• Golden Eagle Fuel Rail
• Injector Dynamics 1000cc Injectors
• Edelbrock Victor X Manifold
• Aeromotive Fuel Pressure Regulator
• Omni Power 68mm Throttle Body
• Hondata Intake Gasket
Turbo and Items
• 6265 Precision Journal T4
• JDL Custom Turbo Manifold
• Precision Intercooler 31 ½ L x 8 in x 3 ½ in
Intercooler Piping
• Tial Bv 50mm BOV
• Precision 46mm WGA
• Intercooler Piping Couplings
• 3 Inch Downpipe
• Tony 1 Catch Can Setup
Trans
• Quaife Lsd
• Stage 5 Spec Clutch
• Billet Aluminum Pressure Plate
• Lightweight Flywheel
Miscellaneous Items
• Hondata s300
• OBD1 to OBD2 Jumper Harness
• Hasport Mounts
• 99/00 Front End Conversion
• K Sport Coilovers
• ASR Sub frame Reinforcement
• ASR Sway Bar Setup
• Blox Lower Control Arms
• Skunk 2 Camber Kit
• Si Taillights
• Rear Integra Disc Conversion and P Valve
• Drilled/Slotted Rotors
• Extended Lug Studs
• Mishimoto Radiator
• PJDM Engine Bay Dress Up Kit
• Benen Strut Tower Bar
• Beaks Lower Tie Bar
Old May 19, 2011 | 05:48 AM
yzracer323's Avatar
Default Re: JDM@SF#CK Chase For 600HP
Good stuff, I have a similar setup. Post up some pics!
Old May 19, 2011 | 06:01 AM
JDM@sF*ck's Avatar
I will Man thanks what did you make?
Old May 19, 2011 | 06:17 AM
yzracer323's Avatar
Im about to revisit the dyno after a bunch of upgrades, last year I made 486whp on pump gas, ran out of fuel. I added an 044 pump inline and ID1000s for a race gas tune, I'll stop at around 600whp.
Turpid Porpoise's Avatar
im building a fairly similar set up right now, in for results
Old May 19, 2011 | 06:33 AM
CDecker0218's Avatar
You should reach your goal. nice set up as well.
Old May 19, 2011 | 07:01 AM
JDM@sF*ck's Avatar
Thanks Guys I will keep all you updated Jim Justice told me my block was capable of making 800hp with a few upgraded parts. . . That will be one day in the future Lol
Old May 19, 2011 | 07:15 AM
JDM@sF*ck's Avatar
Im also loooking for parts if you guys knw anyone selling anything posted above. . .I would appreciate if you guys kept an eye for me and pm me if you find any killer deals
Old May 19, 2011 | 07:36 AM
kyden's Avatar
why a 5 layer headgasket?
Old May 19, 2011 | 07:43 AM
JDM@sF*ck's Avatar
Because i cant use OEM headgasket on a 83mm bore . . .You can only use a OEM headgasket up to 82mm bore
Old May 19, 2011 | 07:47 AM
JDM@sF*ck's Avatar
all though i can go with a 3 layer cometic head gasket which i might do
Old May 19, 2011 | 07:58 AM
kyden's Avatar
or golden eagle.
Old May 19, 2011 | 08:18 AM
JDM@sF*ck's Avatar
Ok i will check into them thanks for the input
Old May 19, 2011 | 05:09 PM
JDM@sF*ck's Avatar
Pics Up Of Car
Old May 20, 2011 | 08:12 PM
Boosted97Ej8's Avatar
Why cant i post up any pics?
Old May 21, 2011 | 02:22 AM
SD_Lurker's Avatar
HT White Ops
Yeah you can certainly get a 83mm OEM head gasket from Golden Eagle. I'd stay far away from a 5 layer gasket.
Old May 21, 2011 | 06:49 AM
Yeah thats what i just looked at the other day
Old May 23, 2011 | 05:25 AM
JDM@sF*ck's Avatar
Here Are Some Pics Of Pulling The single cam motor out, Car is now ready for tuck and bay is ready to be repainted
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old May 23, 2011 | 05:41 AM
TheShodan's Avatar
Moderator
You definitely have your work cut out for you, so I wish you the best of luck and good fortune. Make sure before you start "tucking" anything that you have replaced and repaired a lot of those rubber hoses. Some looked damaged and cracked. Others look very worn. There's no point tucking if you can't get those items repaired first.
Old May 23, 2011 | 05:47 AM
JDM@sF*ck's Avatar
Yeah everything will be new from honda man yeah im getting my buddy From Momentem Auto Werks To Tuck And Paint For $600
Old May 24, 2011 | 05:36 AM
Block is now dropped off, it will be about 30 days before i get it back Pics will be up as soon as i get it back
Old Jun 10, 2011 | 12:19 PM
Default Re: Chase For 600HP
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jun 10, 2011 | 03:22 PM
yzracer323's Avatar
Cool
Old Jun 15, 2011 | 06:00 PM
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jun 15, 2011 | 07:26 PM
eg_YANG's Avatar
It's always better when u build it urself.
Gl on ur build!
