Changing boost and tuning ?
Old Oct 24, 2009 | 05:39 PM
azandford's Avatar
Default Changing boost and tuning ?
I juts bought a 98 civic dx with a full b16 a2 swap and pushing 13 psi with the basic boltons, cam gears, some head work. It was tuned by the last owner but i m afraid of running that much boost on a daily basis even though the engine was completely built to handle it with performance rods and piston ect... It pushes 300 hp and i was wondering if i could turn the boost down to like 6-7 psi w/o having to get it retuned. It has a manual boost controller. This is my first civic so im not really familiar with all the ins and outs coming from 4 mustangs in a row.
Could i change the boost to my liking w/o any ill effects between everyday commute and some night racing? Also can a well built engine handle that much boost on a daily basis since im not driving more than an hour total?
Old Oct 24, 2009 | 06:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Changing boost and tuning ?
down, yes. up? no.
if the car was properly tuned, all of the boost columns to the point you have the highest boost should have been covered.
Old Oct 25, 2009 | 06:18 AM
Silva Bullit DC4's Avatar
The answer is yes. In fact STOCK B16's can handle 300 whp on a daily basis with flying colors, granted the motor is healthy and the tune is spot-on. You're fine. I would leave it the way it is.
You are at a quite conservative power level for a built B16, so dont worry about how much psi your pushing. Excessive torque, high cylinder pressures & detonation is what kills motors, not psi. Drive that bish and have fun, homie.
Old Oct 25, 2009 | 06:56 AM
TurboK's Avatar
If you want to run a lower boost level you must first determine your WG spring will allow you to go that low.
Old Oct 25, 2009 | 07:24 AM
icucnme's Avatar
Yeah you can only go as low as your waste gate spring. Maybe contact the guy you bought it from and see if he remembers what it is.
azandford
Oct 24, 2009 06:12 PM
aalb1
Nov 15, 2005 02:09 PM
ochsy03
Mar 24, 2005 08:53 AM
