cermaic coatings ????????
Old Jul 12, 2005 | 11:29 PM
  #26
Drew Peacock's Avatar
Default Re: (Cloner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cloner &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt do pistons or valves myself dont really think they need it.Doing headers and exhaust turbines is easy for me.To remove the oils you use a propane torch not chemicals.Then you can sandblast it or use sandpaper(takes a long time) Then wash it throughly with dish soap let it dry not much prep work really.Im just the type of person who does everything myself I like to learn.Only thing I ever take to get done is machine work.I havent taken my car to a shop in 10 years.</TD></TR></TABLE> They use some stupidly expensive equipment to lay on the Hiper Coat Extreme you certainly aren't getting that stuff in a can... A ceramic coating yes, but nothing like that. On a build with a lot of money in it I would say its well worthwhile for manifold dump pipe etc. Some people will argue against doing the pistons I think...
I had my old manifold and I/C piping coated in just there alloy type coating (lower heat rating) came out nice, ended up wrapping the manifold with good results seeing that the ceramic coating kept the water out of the steel. Still looks good after 3years and a front end collision.
Old Jul 13, 2005 | 04:28 AM
  #27
dasher's Avatar
Default Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">i'm rebuildin my motor sleevin and everything...dasher you would get ur pistons coated?.....i'm rebuildin for longevity..</TD></TR></TABLE>
If you have a plenty of extra money to laying around go for it. Otherwise their are more important things to purchase first before doing something as special as coating your pistons.
AccludeDreamer
Sep 18, 2009 09:01 PM
wernhersey
Oct 28, 2007 12:50 PM
bigmike77692006
Mar 30, 2006 08:52 PM
dso
Jan 21, 2005 10:22 PM
