CEL Code 3 MAP Sensor. Jackson Racing
Old Sep 14, 2005 | 06:57 AM
debogsr's Avatar
Default CEL Code 3 MAP Sensor. Jackson Racing
The other day i was driving home and my CEL came on in first gear @ around 6 psi. I got home, checked the code, and saw it was the MAP sensor. Started the car again and it turned off. Then on my way back out again it flashed on for about 5 seconds and turned off again @ around probably 3 psi.
What is going on? SHould i be worried? It drives normal still.
JRSC on a Stock OBD1 GSR tuned with Hondata yesterday.
Thanks alot
Old Sep 14, 2005 | 01:49 PM
debogsr's Avatar
Default Re: CEL Code 3 MAP Sensor. Jackson Racing (debogsr)
anyone ever experience this?
Old Sep 15, 2005 | 08:27 AM
debogsr's Avatar
=0/
Old Sep 17, 2005 | 01:04 PM
debogsr's Avatar
Yeah, so....
Drove down to school. Halfway through the trip the car started running like ****. The CEL came on and again it was CEL 3. I just kept it out of boost and made it to where i needed to go. I opened the MAP sensor up and there looked to be Oil in the plug of the sensor. ( probably from the SC install) I tried to clean it out and plugged it all back up and drove it around that night and it ran fine.
This morning, I was driving around and then the CEL came on again and it ran like **** once more. I then took it to a tire shop and tried to blow the oil out with compressed air but the same thing is happeneing.
Im pretty sure this is my prob...
Anyway to clean map sensors???? Should i get a OEM replacement or something aftermarket.
Old Sep 17, 2005 | 08:54 PM
debogsr's Avatar
BUMP
Tried a new MAP sensor and still no luck. Im thinking it might be the connector (female).
I DONT KNOW WHATS GOING ON.
Car still idles like **** and doesnt drive nice at all.
Still CEL code 3...
Please help.
Thanks guys
Old Sep 18, 2005 | 09:07 AM
debogsr's Avatar
TTT
If you read this bump it for me. School starts tomorrow and its a far bike ride =0/
Thanks
Old Sep 18, 2005 | 03:43 PM
debogsr's Avatar
bump
Old Sep 18, 2005 | 06:44 PM
213374U's Avatar
0x5359-0055
Community Builder
You're throwing a code because the MAP sensor is reading pressure. On an N/A car, the MAP will only read vacuum. When you cross into boost (pressure), the MAP sensor is thinking "WHAT THE ****!?!?!?! Something is wrong" and then goes into limp mode. This is why the CEL isn't on when you turn the car off and then start it again.
Easiest way to solve this problem is a check valve/missing link. It allows vacuum to the MAP but closes when you cross into boost
Old Sep 18, 2005 | 07:02 PM
debogsr's Avatar
Default Re: CEL Code 3 MAP Sensor. Jackson Racing (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">You're throwing a code because the MAP sensor is reading pressure. On an N/A car, the MAP will only read vacuum. When you cross into boost (pressure), the MAP sensor is thinking "WHAT THE ****!?!?!?! Something is wrong" and then goes into limp mode. This is why the CEL isn't on when you turn the car off and then start it again.
Easiest way to solve this problem is a check valve/missing link. It allows vacuum to the MAP but closes when you cross into boost </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">
Heres a dyno link just for fun...
http://media.putfile.com/000_0005
BUMP
Modified by debogsr at 5:44 AM 9/19/2005
Old Sep 18, 2005 | 09:23 PM
hondaeg8's Avatar
so it started happening after you got tuned?
Old Sep 18, 2005 | 09:37 PM
debogsr's Avatar
Default Re: CEL Code 3 MAP Sensor. Jackson Racing (hondaeg8)
yup, car ran fine on the dyno, and for a few days after.
Then one night this happened, but the next morning it drove normal again.
Three days later, it started back up and now it wont go back to normal
=0/
Old Sep 18, 2005 | 09:40 PM
hondaeg8's Avatar
get it tuned again
i'm using the jrsc on a gsr motor with the jr map mod and fmu, no problems what so ever with my set up
Old Sep 18, 2005 | 10:41 PM
debogsr's Avatar
I think im good. It ran very well for the few days it was running, and i want my engine to last @ 8 psi.
Plus i didnt invest in hondata/RC injectors/ fuel pump for nothing.
Old Sep 18, 2005 | 11:33 PM
9hatch2's Avatar
missing link.
Old Sep 19, 2005 | 05:57 AM
debogsr's Avatar
Default Re: CEL Code 3 MAP Sensor. Jackson Racing (9hatch2)
Why am i going to run a missing link when i have HONDATA...
am i missing something?
Old Sep 19, 2005 | 06:14 AM
petersayarath's Avatar
im having the exact same problem but with my turbo set-up.. t3/t4 turbonetics.. i would love to know too.. and oh yeah, by the way, im running the missing link! is there any possible way it can be incorrectly installed?
Old Sep 19, 2005 | 06:43 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (petersayarath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">Why am i going to run a missing link when i have HONDATA...
am i missing something?</TD></TR></TABLE>
Sorry, missed that
Old Sep 19, 2005 | 01:23 PM
debogsr's Avatar
Default Re: (Vt4cPwn35)
So more updates on me troubleshooting but still no solution.
I got a female connector from a junkyard and soldered it in (the plug that the map sensor plugs into) and tried to start it up. Still the same problem.
I then started just checking random things that i had to cut and solder and when i tugged on these wires they came out of the plug...
I pushed them back in and the car still idled like ****.
CLIFF NOTES
SO far i have tried a new MAP sensor and sensor plug, and i am still running redicluously rich and idling like crap....
Somebody has got to have some kinda advice for me. What should i check next??? THanks
Old Sep 19, 2005 | 01:25 PM
debogsr's Avatar
Default Re: (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">TTT
Thanks</TD></TR></TABLE>
Yeah, and to make things worse i had to ride my bike and got pulled over by a cop and got a ticket for riding on the wrong side of the road...
Old Sep 19, 2005 | 01:49 PM
213374U's Avatar
0x5359-0055
Community Builder
ROTFL..... j00 g0t pwn3d
Old Sep 19, 2005 | 05:49 PM
debogsr's Avatar
up again for help.
please
Old Sep 20, 2005 | 12:18 PM
debogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">up again for help.
please </TD></TR></TABLE>
Old Sep 20, 2005 | 04:52 PM
debogsr's Avatar
200 views and nobody has any advice?????
Come on now i dont want another biking ticket.
Old Sep 20, 2005 | 05:00 PM
urbansi's Avatar
YOU NEED A MISSING LINK, STOCK MAP SENSOR SHOULDN'T READ POSITIVE MANIFOLD PRESSURE
Old Sep 20, 2005 | 05:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (urbansi)
he has a hondata s200b tuned for use with boost (i hope you have the boost option). you ************* cant read for ****.
if its tuned for boost you dont need a missing link. jesus christ
i think its a problem with hondata,
