Cause of this damage<experts needed>
Old Feb 8, 2005 | 09:53 PM
Alstare's Avatar
Default Cause of this damage<experts needed>
My friend just sent me some pics of what damage was on his dsm, he couldn't find any help anywhere else, so I told him I'd put it up here since there is alot of pro's on here. These's are 9:1 Wiseco's in 4g63 6olt, with maybe 2000miles max on the motor.
Engine was assembled by a local shop with a good rep., the owner of the car takes great care of the car, regular oil changes, good tuning, good break in, etc...
The rings basically never set, the compression went up and down alot, and he got sick of it and pulled the head to find this.
Any Idea's or opinion's? I have never personally seen a piston and scratched up above the top ring so I have no idea. Also the top rings are a bit seized in the grooves. 2 are like this and 2 are basically fine, he's gonna spec out everything this week to check for assembly problems, just though maybe we could get some insight before then...
Old Feb 8, 2005 | 10:10 PM
Alstare's Avatar
Default Re: Cause of this damage<experts needed> (Alstare)
Sorry for the bad pics, was the only pics he had...
Old Feb 8, 2005 | 10:21 PM
wantboost's Avatar
Who is Mr Robot?
lack of cylinder wall oiling?
Old Feb 8, 2005 | 10:28 PM
b18cx's Avatar
Default Re: Cause of this damage<experts needed> (wantboost)
Looks like someone screwed up on the measurments during assembly, OR during break-in, it was running lean and the piston over expanded.
Old Feb 9, 2005 | 04:18 AM
Jared's Avatar
Default Re: Cause of this damage<experts needed> (b18cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">Looks like someone screwed up on the measurments during assembly, OR during break-in, it was running lean and the piston over expanded.</TD></TR></TABLE>
exactly. that is a sign of piston to wall clearances being too tight, either as measured by the machine shop or because of detonation and an overly excessive lean air/fuel mix
Old Feb 9, 2005 | 04:35 AM
NJIN BUILDR's Avatar
Looks like too much timing.If it was just to tight you would see the scuffing mostly below the rings on the the skirts.The scuffing at the top means it saw a lot of heat.The top of the piston is considerably smaller than the bore and even a couple thousands to small isn't a problem until the heat goes out of site.Rings will seat better if its a little lean as long as the loads are light.
Glenn
Old Feb 9, 2005 | 05:55 AM
Benjithx's Avatar
Default Re: Cause of this damage<experts needed> (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Looks like too much timing.If it was just to tight you would see the scuffing mostly below the rings on the the skirts.The scuffing at the top means it saw a lot of heat.The top of the piston is considerably smaller than the bore and even a couple thousands to small isn't a problem until the heat goes out of site.Rings will seat better if its a little lean as long as the loads are light.
Glenn</TD></TR></TABLE>
agreed
BigBlock22
13
Nov 11, 2009 09:20 PM
94-integra-ls
Appearance Build Threads
Aug 22, 2008 09:19 AM
GSE980
Aug 12, 2006 04:02 PM
lke2drvgsr
Apr 29, 2004 05:48 PM
AzG35
Jul 2, 2003 11:19 PM
