catch can setup, will this work?
Old Oct 11, 2007 | 11:52 PM
chunkybs's Avatar
Default catch can setup, will this work?
i have a greddy catch can, (it was free, don't bitch about me wasting money). i ran 1 line from the PCV valve to the can and the other line from the can to the intake pipe coming off my turbo. does that seem right?
this is the one i have.
Old Oct 12, 2007 | 06:24 AM
chunkybs's Avatar
bump
Old Oct 12, 2007 | 06:42 AM
ham's Avatar
ham
Default Re: catch can setup, will this work? (chunkybs)
what motor is it?
Old Oct 12, 2007 | 07:20 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">i have a greddy catch can, (it was free, don't bitch about me wasting money). i ran 1 line from the PCV valve to the can and the other line from the can to the intake pipe going to my turbo. does that seem right?
You meant to say what I have bolded correct?
What you propose will work, but it can be better.
First off, I'd put some aluminum mesh in the can for added surface area. Then I'd remove the PCV valve altogether and replace it with a straight male/male connector.
You go even further, you can also remove one of the block plugs in the back and run a line from there to the other hole, tap a hole in the top of the can and put on a breather filter.
Old Oct 12, 2007 | 09:20 PM
chunkybs's Avatar
Default Re: catch can setup, will this work? (ham)
turbo z6
Old Oct 13, 2007 | 02:01 AM
90sedan's Avatar
Remove the PCV valve and run the line straight from the black box to the catch-can. Then run the other line back to the valve cover.
I would recommend putting a breather filter on the catch-can though.
Old Oct 13, 2007 | 04:40 AM
RACEPAK's Avatar
Default Re: catch can setup, will this work? (90sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan &raquo;</TD></TR><TR><TD CLASS="quote">Remove the PCV valve and run the line straight from the black box to the catch-can. Then run the other line back to the valve cover.
I would recommend putting a breather filter on the catch-can though. </TD></TR></TABLE>
cause without one its just plain stupid...
Old Oct 13, 2007 | 05:29 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">i have a greddy catch can, (it was free, don't bitch about me wasting money). i ran 1 line from the PCV valve to the can and the other line from the can to the intake pipe coming off my turbo. does that seem right?
lol, seems like its going to cause an instant smoke screen.
i still dont know why people run the line from the catch tank into the inlet of the turbo.....
Old Oct 13, 2007 | 06:56 AM
chunkybs's Avatar
Default Re: catch can setup, will this work? (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">
i still dont know why people run the line from the catch tank into the inlet of the turbo..... </TD></TR></TABLE>
provides vacuums to pull the oil out of the PCV valve. you can't pull from the intake manifold if your boosted because when in boost it will pressurize the crank case.
anyone have a write up on hooking it right to the black box?
ALL IMPORT
Mar 12, 2006 03:45 PM
sldcivic
Jan 18, 2006 09:14 AM
eluder33
Mar 24, 2005 11:19 AM
d15b7racer
Aug 8, 2003 11:15 PM
wickedxboi
Feb 25, 2003 09:33 PM
