Catch Can Rerout back to the block
Old May 22, 2006 | 02:04 PM
Quad-Damage's Avatar
Default Catch Can Rerout back to the block
Fixed Thanks!
Modified by Quad-Damage at 5:03 PM 5/23/2006
Old May 22, 2006 | 02:31 PM
Default Re: Catch Can Rerout back to the block (Quad-Damage)
Fixed
Old May 22, 2006 | 02:46 PM
SOHC_MShue's Avatar
haha i dont think that slight bit of extra oil is your problem. Try mounting the catchcan higher so it can drain back.
Old May 22, 2006 | 02:48 PM
Default Re: Catch Can Rerout back to the block (SOHC_MShue)
maby runing the lines over the intake manfoild would help? It just looks cleaner when **** is hidden
Old May 22, 2006 | 03:13 PM
I Have an STD's Avatar
wrenchin'
run the drainback into the hole for the factory black box, just make sure the catch can is mounted higher than the hole for the black box
Old May 22, 2006 | 03:39 PM
Default Re: Catch Can Rerout back to the block (I Have an STD)
i took out the black box
Old May 22, 2006 | 03:40 PM
i just mounted it near my AEM Fuel Filter thats as high as it will go, and i moved the lines over the intake manifold, im about to take it for a test drive and see if that helped
Old May 22, 2006 | 03:59 PM
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">i took out the black box </TD></TR></TABLE>
what did u plug the hole with?
Old May 22, 2006 | 04:50 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">maby runing the lines over the intake manfoild would help? It just looks cleaner when **** is hidden</TD></TR></TABLE>
yea anything i guess to sit it higher. My friend's motor used to fill one up in like a day and it was a huge *** catch can too because he had it mounted on level with the hole.
Old May 22, 2006 | 05:46 PM
nerdsports's Avatar
it seems like the 2 taps in the valve cover are too low.
you need to tap the valve cover where the oil baffle is at.... otherwise it just blows out all the oil splashing around.
Old May 22, 2006 | 05:52 PM
DaveF's Avatar
Default Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">it seems like the 2 taps in the valve cover are too low.
you need to tap the valve cover where the oil baffle is at.... otherwise it just blows out all the oil splashing around.</TD></TR></TABLE>
also. please comsider which direction the oil is moving, while you are moving foward..... it will get slammed against the rear of the valvecover. that combined with the crankcase pressure is sure to push alot of oil. also, you will have better results with a larger diameter hose.
Old May 22, 2006 | 06:21 PM
igo4bmx's Avatar
yeah im gonna mount mine to the front of the valve cover...
also since no one mentioned it. do not T it to the oil sandwich adapter! That is pressuried
Old May 22, 2006 | 06:51 PM
ladysman's Avatar
Anthrax-VX
Apr 27, 2004 09:37 PM
fastludeh22
Aug 26, 2003 06:46 AM
jisu009
Jul 13, 2003 07:50 PM
PROFILES2000
Nov 4, 2001 06:24 PM
