Catch Can Install
Old Aug 28, 2005 | 10:04 PM
maurob18a1's Avatar
Default Catch Can Install
Okay this is the new way I have it set up.... Let me know if this is better
Modified by maurob18a1 at 4:09 PM 8/29/2005
Old Aug 28, 2005 | 10:24 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Catch Can Install (maurob18a1)
bump
Old Aug 28, 2005 | 10:50 PM
jDMJeRk's Avatar
I cant see what your hoses are going too. but it looks like the vapors are still going into your IM
Old Aug 28, 2005 | 10:52 PM
maurob18a1's Avatar
the thing on the right is the catch can. I will be putting some type of metal sponge in there to filter the air
Old Aug 29, 2005 | 02:47 AM
non-VTEC's Avatar
ya that's hooked up correct....
Old Aug 29, 2005 | 03:29 AM
bubs's Avatar
Can't really see what's going on, but unless the line going from the can to the IM has some sort of check valve, it's not hooked up correctly. You might also want to hollow out your PCV valve if you haven't already for better flow.
Old Aug 29, 2005 | 04:46 AM
mike1114's Avatar
Default Re: (bubs)
NO YOU DO NOT HAVE IT RIGHT.
basically right now, your sucking out of the valvecover and into your intake manifold. You have just duplicated the factory setup almost.
Man, read up on this some more or IM me for more details on how to do it right. It will be some work though.
P.S. Holy vacuum tee's batman!!!
Modified by mike1114 at 2:48 PM 8/29/2005
Old Aug 29, 2005 | 05:35 AM
jDMJeRk's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">NO YOU DO NOT HAVE IT RIGHT.
Man, read up on this some more or IM me for more details on how to do it right. It will be some work though.</TD></TR></TABLE>
Thats what I thought I saw and also; isnt your catch can supposed to sit vertical not horizontal? (thats just how it looks in the picture
Old Aug 29, 2005 | 06:58 AM
maurob18a1's Avatar
that is what I was thinking... so I have changed it as of this morning.. pics coming up later. I tried to get a visual from other setups by searching on the internet, but couldn't find anything
Old Aug 29, 2005 | 07:51 PM
NuclearB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maurob18a1 &raquo;</TD></TR><TR><TD CLASS="quote">Okay this is the new way I have it set up.... Let me know if this is better
Modified by maurob18a1 at 4:09 PM 8/29/2005</TD></TR></TABLE>
is this a different picture than the one that was originally posted? if so, is this set up the right way?
Old Aug 29, 2005 | 07:56 PM
SL0WEGG's Avatar
Default Re: Catch Can Install (NuclearB18B)
dont think so because the intake manifold is creating the vacuum but its still sucking it back into it from the looks of it. arent you supposed to run one line from the intake manifold to the catchcan and another from the valve cover to the catch can? By doing that you create a vacuum to suck the oil or whatever into the catch can and not back into your intake manifold. well thats just how i see it
Old Aug 29, 2005 | 08:30 PM
Just Another Civic's Avatar
Default Re: Catch Can Install (boostedej1)
{search} PCV
(click} The Official Crankcase Evacuation thread for Turbo Hondas
{read) (again and again)
{hook up system correctly}
or just click on this link: https://honda-tech.com/zerothread?id=1199935
Old Aug 29, 2005 | 08:40 PM
Sprockets's Avatar
No, it's not hooked up correctly. Is that PCV hollowed out? If not, there's no vacuum to open it. Right now you have the valve cover breather, and your PCV going to a vented catch can. No matter what, you should not run the valve cover line and pcv hose to the same catch can. If you have those 14mm hex plugs in the back of your block, you can do an Endyn type setup. Otherwise, just remove the pcv, and put the largest size brass fitting you can fit in its place. From there, it should go directly to the catch can with no T, and an open breather on the catch can. Either get a second catch can, or put a breather filter on the valve cover breather separate from the other catch can.
Old Aug 30, 2005 | 01:48 AM
maurob18a1's Avatar
okay so here is what I think I understood
Old Aug 30, 2005 | 10:00 AM
Sprockets's Avatar
Default Re: (maurob18a1)
If you want to use the PCV valve, then you need the manifold vacuum source. Otherwise, cap it. You don't need a vacuum source if you remove the PCV and use the block fittings in the picture.
According to Z10, both block fittings aren't needed, but most people use 2. If you choose to use just one, use the passenger side. You could also drill and tap the top of your catch can and screw in a barbed fitting for a breather filter so you can run 2 lines. Since I'm not familiar with LS engines, I can't comment on how to plug the stock PCV.
Old Aug 31, 2005 | 01:27 AM
maurob18a1's Avatar
Here is a thread that has it intalled like I originally had it installed
http://www.c-speedracing.com/h...n.php
Old Aug 31, 2005 | 11:28 AM
Sprockets's Avatar
Which way? From the PCV to the catch can to the intake manifold? This is fine, except the PCV closes under boost. However, many people do this anyway. His other suggestion ("If your motor didn't have an original PCV system, then run one line from the nipple you installed on the back of the block to the catchcan and then run a vacuum line from the catchcan to the intake manifold."), doesn't sound like a good idea. I've read that steel wool isn't a good idea, either.
Look up posts made by "dasher" to learn about catch can setups. There are several different ways of hooking them up.
Old Sep 27, 2005 | 10:11 PM
PINKS's Avatar
I want a CRX tattoed on my butt
subscribe
turbosivtec
Mar 21, 2012 02:43 PM
type B16
Sep 24, 2006 04:14 PM
TOFU.man
May 18, 2004 09:42 PM
civictypenos
Sep 14, 2003 10:10 AM
Ronin Panda
Mar 30, 2003 11:51 AM
