d series valve cover question
how come some have the spark plugs in the front of the valve cover and some have them in the back. what is the difference? sorry if its a dumb question.
Re: d series valve cover question (4door93civic)
are you talking about a d series (front) and b series (middle)?
i thought all d series had them in the front. maybe someone installed their engine in backwards
Re: (infinatenexus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus »</TD></TR><TR><TD CLASS="quote">The early D series motors had them in the back,, the newer ones are in the middle/front</TD></TR></TABLE>
Thats about it, just an easy way of figuring out how old it is at a glance....also the older ones with the sparkplugs on the back say 16 valve, while the 96+ d series just say honda and the valve cover isnt painted black there just aluminum
Re: (civiksiracer1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiksiracer1 »</TD></TR><TR><TD CLASS="quote">yes the Sohc non vtecs were in back, and the sohc vtec were up front...</TD></TR></TABLE>
NO. Example: D16y7.
NO. Example: D16y7.
Re: (brooksto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brooksto »</TD></TR><TR><TD CLASS="quote">
NO. Example: D16y7.</TD></TR></TABLE>
yep I was about to say...
its just a change...like how the z6 said vtec and the y8 doesnt
Re: (civiksiracer1)
i believe 92-95 vtec's had the plugs in the front & non vtec's had them in the back. all 96 & up are in the front, correct me if i am wrong.
Guest
Posts: n/a
Re: (brooksto)
I belive that honda just designed the motors a bit differently but their main intention was to put most non-vtec motor spark plugs in back and vtec spark plugs in front
Risky Business
Re: (white ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex »</TD></TR><TR><TD CLASS="quote"> i believe 92-95 vtec's had the plugs in the front & non vtec's had them in the back. all 96 & up are in the front, correct me if i am wrong.</TD></TR></TABLE>
Yep
1988-1996:
Plug wires in front: SOHC VTEC
Plug wires in back: SOHC NOTEC
1996-00:
Plug wires in front: EVERYTHING
Yep
1988-1996:
1996-00:
Re: (BauleyCivic)
i have a sohc zc with the spark plugs in the front. does that mean its a vtec motor? did they make a vtec zc?
Risky Business
Re: (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door93civic »</TD></TR><TR><TD CLASS="quote">i have a sohc zc with the spark plugs in the front. does that mean its a vtec motor? did they make a vtec zc?</TD></TR></TABLE>
Probably. Does it have a VTEC solenoid on the left side of the head? They did make an SOHC VTEC ZC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm »</TD></TR><TR><TD CLASS="quote">Doesn't the Y7 have a 3 stage econo-VTEC or something? Or was it another D engine?</TD></TR></TABLE>
Nope, thats the JDM D15B. 1 Intake valve is open till 2500 to save fuel, then its normal operation until 5000, then the 2nd intake cam profile opens for VTEC at 5000.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Nope, thats the JDM D15B. 1 Intake valve is open till 2500 to save fuel, then its normal operation until 5000, then the 2nd intake cam profile opens for VTEC at 5000.</TD></TR></TABLE>
Bah, I suck at VTEC engines.
I thought the JDM D15B was like a 1.5 litre Z6, but we had one engine that had a 3-stage VTEC like you mentioned.
Re: (clm)
on my zc on the left side where the vtec selonoid goes there is a piece of metal bolted over it instead of a vtec selonoid.
Re: (4door93civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door93civic »</TD></TR><TR><TD CLASS="quote">on my zc on the left side where the vtec selonoid goes there is a piece of metal bolted over it instead of a vtec selonoid.</TD></TR></TABLE>
You=no vtec.
You=no vtec.
