Car Sparactically Running bad
Old Oct 18, 2011 | 02:34 PM
JDM IN MY SOL's Avatar
Default Car Sparactically Running bad
Lately in the morning the car seems to have a misfire after driving on the highway for 15 or so minutes. Every time the car is fully up to temp. It will sputter so bad I have to pull over cause theres no power. Once pulled over I restart and can usually be on my way and problem free the rest of my 50 mile trip to work. After work I drive home problem free. It seems to be when the car has sat for an extended time that this happens. Car runs great in boost like normal.
so far Ive replaced
- OEM Cap
- OEM Rotor
- NGK plugs gapped at .22
Setup
- OBD0 B16
- arp headstuds
- gsr cams
- Garrett t3/t04E 60./.63
- Ramhorn
- Tial 38
- Open Downpipe
- ETC
365whp 325Tq on 18psi 93 octane
Car has been fully tuned by a reputable tuner since June 1 2011. Ive logged 8,000 miles since then. Any help would be greatly appreciated
Old Oct 19, 2011 | 06:12 AM
00si2's Avatar
Default Re: Car Sparactically Running bad
I have something similar going on with my car but not as bad. When im crusing on the highway i get a jerking when im trying to maintain speed with light throttle. Giving it a little more throttle makes it go away. Doesnt always do it but on and off like you.
Does your problem get better or worse depening on outside air temperature? The colder it is the better mine seems to run.
So far ive done the same as you and also replaced fuel filter, adjusted the valves, and checked the timing.
Bump for answers.
Old Oct 19, 2011 | 07:16 AM
rich7777's Avatar
What are both your ARF's when your experiencing this problem ?
Old Oct 24, 2011 | 07:01 AM
00si2's Avatar
Im showing between 16 and 17
Old Oct 24, 2011 | 07:10 AM
rich7777's Avatar
Thats the problem, it running way to lean. Go and see your tuner.
Old Oct 25, 2011 | 01:17 PM
i dont have a wideband. Seems to only be partial throttle too
PayMecracka
15
Sep 6, 2011 03:34 PM
buzlink
Dec 29, 2005 08:45 PM
underpressure02
Aug 23, 2005 06:54 PM
8200RPM
May 2, 2004 10:09 AM
