Car just dies
Old Jan 21, 2008 | 07:58 AM
mitsuman's Avatar
Default Car just dies
Ok so after starting the motor and warming it up, it seemed to be running fine. But then it just started to die. I would turn it on, rev it a little and it would cut out. It drives fine, but as soon as i let off the gas and clutch, off it goes. i want to get this thing to the dyno this weekend but cant if i have this problem.
anybody got any suggestions. thanks
setup:
94 gsr long block, sleeves, pistons, rods, skunk 2 im, stock TB, "silver surfer" turbo, gm 3 bar map.
Old Jan 21, 2008 | 08:04 AM
DaveF's Avatar
Default Re: Car just dies (mitsuman)
iac plugged in ?
map sensor plugged in ?
Old Jan 21, 2008 | 08:21 AM
mitsuman's Avatar
Default Re: Car just dies (DaveF)
yes, yes.
i am getting a check engine for knock sensor though. but that shouldn't make a difference. right?
Old Jan 21, 2008 | 10:39 AM
red_crx's Avatar
Does the 3bar have a good vacuum source?
does the needle on you rpm guage bounce all over the place before it dies?
Old Jan 21, 2008 | 10:54 AM
mitsuman's Avatar
Default Re: Car just dies (red_crx)
yes map is getting its reading from my vacuum manifold which is t'd up to brake booster line.
no, not bouncing everywhere. just goes down down down, and dies.
Old Jan 21, 2008 | 11:08 AM
NonovUrbizniz's Avatar
Loved
Did you set your idle by disconnecting the IAC and turning the idle adjuster screw then plugging back the IAC?
What management?
Old Jan 21, 2008 | 12:49 PM
SovXietday's Avatar
Default Re: Car just dies (NonovUrbizniz)
Increase IACV duty cycle and see if that helps. What management are you using?
Old Jan 21, 2008 | 02:07 PM
mitsuman's Avatar
thats the thing it will idle sometimes for a little bit, then just die. so i know its not my idle screw.
i am running s300. ill try to mess wth the iavc settings.
Old Jan 21, 2008 | 02:58 PM
Loved
Is your timing set to stock?
Did you follow the procedure to set the idle? Disconnect the IAC and try to get it to idle at 450?
Obviously that will be hard to do now...
I'd try to set the idle speed higher till it holds then try to trace down the problem...
What map are you running has it been tuned already?
It's sounds like a IACV or timing problem.
Old Jan 21, 2008 | 05:12 PM
mitsuman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">Is your timing set to stock?
It's sounds like a IACV or timing problem.</TD></TR></TABLE>
the timing is off i know that. but i know its not the timing. because i had this problem before. and it is not every single time i turn the motor on.
i did not follow that procedure. im running gm 3bar map. could iacv be dirty?
Old Jan 21, 2008 | 05:30 PM
Mikey3000's Avatar
if u have any vacuum ports plugged on the IM or TB, unplug it and see if it changes anything.
Old Jan 21, 2008 | 06:40 PM
mitsuman's Avatar
Default Re: Car just dies (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">if u have any vacuum ports plugged on the IM or TB, unplug it and see if it changes anything.</TD></TR></TABLE>
um i would imagine that would be a nice little vacuum/boost leak. ??
Old Jan 21, 2008 | 06:58 PM
SovXietday's Avatar
A) Get your mechanical timing correct.
B) Set your idle timing to a few degrees advance (18-20), it will help the car idle.
C) Clean your IACV out, and also increase the duty cycle in Hondata and see if that helps.
Start with that, if you still have problems then start looking for vac leaks and make sure you're MAP sensor is reading correctly.
Old Jan 21, 2008 | 07:26 PM
mitsuman's Avatar
Default Re: Car just dies (SovXietday)
will do. i just turned her on right now and she ran fine. i also noticed that the iacv duty cycle was low. i turned it up a bit and noticed she ran smoother.
will get all this done and let yall know.
heyitzspikey
Jan 29, 2007 09:19 PM
Running925
Dec 2, 2006 09:24 PM
FERIOkid
Nov 11, 2006 04:07 PM
talley2191
Jan 31, 2006 07:13 PM
turboedsi
Apr 1, 2004 07:37 AM
