Car isn't making boost anymore...
Old Jun 21, 2003 | 03:14 PM
GraphiteAccord's Avatar
Default Car isn't making boost anymore...
To get my setup, do a search under my name....changed the transmission fluid last night, and took the car out. Driving home, the car started boosting less and less...untill now, inwhich it doesn't boost at all. i can hear the turbo spool, the bov goes off, but i only hit like +.02 bar...i put a MBC on it, and tried to turn it up..to no avail..So i checked all of my vaccum lines and my couplers, all seem well. Car still doesn't make boost at all. i had some exhuast leaks from loose manifold bolts, tightened those up asap, and stillm no boost.
What do you guys think?
Old Jun 21, 2003 | 04:49 PM
Default Re: Car isn't making boost anymore... (GraphiteAccord)
its fixed. heh. it was the wastegate adjuster nut...came loose...
Old Jul 5, 2003 | 07:10 AM
arsenaldragster's Avatar
Im having the same problem.. I just installed mine yesterday.. it spools but no boost.. how do i check the wastegate nut you are talking about?
Old Jul 5, 2003 | 03:10 PM
disguy409's Avatar
Default Re: Car isn't making boost anymore... (arsenaldragster)
i'd like to know also... having the same problem.
Old Jul 5, 2003 | 04:23 PM
turbo_ef9's Avatar
Default Re: Car isn't making boost anymore... (disguy409)
me too... is yours external or internal wg? mine went from 9lbs.. to 5-6lbs...
Old Jul 5, 2003 | 04:31 PM
disguy409's Avatar
Default Re: Car isn't making boost anymore... (eli_vang)
mines is external. it was working fine the other day. I just install a mbc yesterday and didn't try to boost until today and it wouldn't go past zero. I checked the charge pipes and everything looks ok.
Old Jul 5, 2003 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disguy409 &raquo;</TD></TR><TR><TD CLASS="quote">mines is external. it was working fine the other day. I just install a mbc yesterday and didn't try to boost until today and it wouldn't go past zero. I checked the charge pipes and everything looks ok.</TD></TR></TABLE>
sounds like the MBC is adjusted wrong
Old Jul 5, 2003 | 08:36 PM
tararan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">To get my setup, do a search under my name....
What do you guys think?</TD></TR></TABLE>
this is off topic but please do not ask question and have the people helping you do the search. you could've atleast added a link to your full set up or copy and pasted it on your thread...
Old Jul 6, 2003 | 02:02 AM
lazerus's Avatar
Default Re: Car isn't making boost anymore... (tararan)
you guys should make boost leak detectors.. man they work well, and cost &lt;13 bucks if you do it right...
Old Jul 6, 2003 | 03:49 PM
Default Re: Car isn't making boost anymore... (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">you guys should make boost leak detectors.. man they work well, and cost &lt;13 bucks if you do it right...</TD></TR></TABLE>
tell us how
Old Jul 6, 2003 | 07:03 PM
turbo_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arsenaldragster &raquo;</TD></TR><TR><TD CLASS="quote">
tell us how </TD></TR></TABLE>
Old Jul 7, 2003 | 01:08 AM
CHK4TIX's Avatar
BIG LUIS
Jul 31, 2014 08:00 PM
Hondacivic1995
Apr 17, 2011 04:40 PM
madracer
May 21, 2009 02:36 PM
TurBoXBirD16
May 10, 2003 10:34 AM
DIRep972
Nov 26, 2001 07:57 PM
