Car is hard to start!
Old Mar 14, 2003 | 09:29 AM
swrdply400mrelay's Avatar
Default Car is hard to start!
I have a Y8 and recently got my P28 converted from an auto to manual. Now when I try to start my car, it won't start. I have to prime my car for about 10 secs before it starts and dies again. So I give it gas to keep the revs up for a few secs. It will idle rough for about 5 secs and then be fine. Any ideas as to what is wrong?
I have my timing retarded a few degrees. I also heard that you are supposed to jumper the blue CEL harness while you adjust timing, but I didn't do that because I just read it somewhere yesterday. Any help is greatly appreciated!
TIA
Mike
Old Mar 14, 2003 | 12:11 PM
Default Re: Car is hard to start! (swrdply400mrelay)
bump
Old Mar 14, 2003 | 12:50 PM
Flamenco-T's Avatar
I never jump any harness when I adjust timing...I don't see why you need to do anything liek that...
does it feels like a lack of fuel ?
Old Mar 14, 2003 | 01:59 PM
Pengo's Avatar
Default Re: Car is hard to start! (Flamenco-T)
actually i think you are supposed to jumper the harness when you adjust ur ignition timing via distributer. someone correct me if i'm wrong
Old Mar 14, 2003 | 02:18 PM
Tofurky's Avatar
Default Re: Car is hard to start! (Pengo)
yes sir
Old Mar 14, 2003 | 11:49 PM
No I don't think it's lack of fuel. I checked my fuel pressure regulator gauge and the pressure is still normal. I think it might be something from the auto to manual conversion. Someone said you should cut rp17 and rp18. It looks like they only cut rp17 and not 18. Could this be why?
Also, why do you need to jumper to adjust timing?
[Modified by swrdply400mrelay, 8:49 AM 3/15/2003]
Old Mar 15, 2003 | 02:42 PM
bump
Old Mar 15, 2003 | 04:50 PM
Spunkster's Avatar
Properly convert your ECU to manual and see if that helps.
Old Mar 15, 2003 | 08:21 PM
Default Re: Car is hard to start! (Spunkster)
What do you mean by that? I sent it in to ag-eng.com aka b18c-ej1 on this forum.
Old Mar 16, 2003 | 07:49 AM
Well I im'd b18c-ej1 and asked him about it. He said I needed to re-chip my ECU since auto and manual have different timing and fuel maps. Is this true?
Schlitzjr
K Series
12
Jun 15, 2015 11:02 AM
go2sleep
May 30, 2007 12:53 PM
Do_Ster
Jul 7, 2004 03:55 PM
hondaeg8
16
May 6, 2004 01:40 PM
thalwr1
Mar 17, 2003 06:24 PM
