clutch slipping?
Old Jul 5, 2006 | 02:46 PM
EF-Honda91's Avatar
Default clutch slipping?
here lately my car has been acting funny? what it does is when i take off in first letting the clutch ingage slowly the car starts to kind of bump bump bump like its slipping or somthing, i dont no if that is the problem or not but i don want this problem going unnoticed, i mean should i heed the warning signs? is my clutch going out?
Old Jul 11, 2006 | 10:12 AM
JMcMusicman's Avatar
Default Re: clutch slipping? (EF-Honda91.)
Before you replace the clutch check for other (cheaper) causes... my 98 Civic did the same thing, took it to the dealer and they said it was the clutch, so I had it replaced. Turned out it was caused by bad spark plug wires!
Old Jul 11, 2006 | 10:31 AM
Ls_V_TurboSi's Avatar
Default Re: clutch slipping? (JMcMusicman)
to me it sounds like your clutch is going out.
To the guy above. I dont see how the spark plug wires would cause your clutch to slip
Old Jul 12, 2006 | 08:12 AM
Surestick's Avatar
Default Re: clutch slipping? (Ls_V_TurboSi)
I think he was suggesting that that a missfire due to bad plug wires could cause the bump bump bump feeling.
If your clutch is slipping it will be obvious.
Old Jul 12, 2006 | 03:03 PM
Default Re: clutch slipping? (Surestick)
Correct the bad wires caused the engine to hesitate during acceleration, the dealer thought incorrectly that it was the Clutch slipping.
Old Jul 12, 2006 | 10:41 PM
qfast817's Avatar
does your rpms jump and not go any where, do you have any oil leaks
trance565
Aug 21, 2006 05:18 PM
egcivicb16
Mar 20, 2006 02:32 PM
lohatch
Dec 13, 2004 07:06 PM
jdmGSRcivic
Nov 19, 2004 12:19 PM
grngsr01
Jun 19, 2003 05:56 AM
