Still no fuel???
Old Jul 11, 2003 | 08:01 PM
GForceInteg's Avatar
Default Still no fuel???
I just installed a aem fuel rail with a holly 255 forced induction pump, but my a/f keeps going to lean when im @WOT. It starts off in the rich then creeps so far into lean it goes off??? NEED HELP PLEASE.
Old Jul 12, 2003 | 08:07 AM
EE_Chris's Avatar
Default Re: Still no fuel??? (GForceInteg)
Just because you have the capacity to supply a larger amount of fuel, does not mean that you ARE supplying a larger amount of fuel.
Old Jul 13, 2003 | 10:09 PM
Default Re: Still no fuel??? (EE_Chris)
then what does this mean because you just totally lost me
Old Jul 13, 2003 | 10:17 PM
MiraiZ's Avatar
it means...getta better fuel setup...
Modified by MiraiZ at 4:35 PM 7/14/2003
Old Jul 13, 2003 | 10:33 PM
Bspec18's Avatar
injectors ? some type of EMS ? FPR ?
Old Jul 13, 2003 | 10:35 PM
MiraiZ's Avatar
Default Re: (Bspec18)
bigger injectors will definatly help too
Old Jul 14, 2003 | 09:34 AM
CRXRageD's Avatar
Get some kind of fuel management system with larger injectors.
Old Jul 14, 2003 | 09:12 PM
Default Re: Still no fuel??? (CRXRageD)
i have the greddy fcu with rc 440's with the holly pump and aem rail? what else do i need?
Old Jul 14, 2003 | 09:16 PM
Pengo's Avatar
what your setup? motor, boost, etc? is the pump intank or inline? i'd say at least get a fuel pressure gauge so you can monitor it. how are u monitoring a/f? autometer led gauge?
Old Jul 15, 2003 | 05:40 PM
Default Re: Still no fuel??? (Pengo)
Internal Engine Work Performed
Double shot pinged rods
JE/SRP 9.1:1 +.20 Oversized Pitons and Rings
STR Block Guard
Square decked block
Shaved head
Crower Double Spring Valve springs
Crower Titanium Retainers
Resurfaced Valves/seats
Holly 255 Forced fuel pump
AEM fuel Rail
Engine Equipment And or gauges
B&M Fuel Pressure Regulator
B&M Fuel Pressure Gauge
AEM Cam Gears
Nology PC-10 Unit
Nology Plug Wires
Denso Iridium Plugs
Greddy T.V.V.C. Manual Boost controller
Greddy Type-S blow off valve
Greddy 18G Turbo Kit (Incuded Fuel Cont. Unit and RC 520cc injectors)
Greddy Small front mount intercooler
HKS Turbo Timer
Autometer Air/Fuel Gauge
Autometer Boost Pressure Gauge
Autometer Oil Pressure Gauge
Straight thru Cat.
Custom 2.5” exhaust brought to dual outs
APR Strut Brace
Engine Settings
Fuel Pressure 52lbs/60@WOT
Intake Valves 2 degrees advanced
Exhaust Valves 2.5 degrees advanced
Blowoff valve Set @ 14lbs.
Boost pressure Reg. 7lbs. Street/14lbs. Strip
Ign. Timing Retarded 2 degrees
Spark plugs 2 degrees colder
Spark plug Gap .028 Gap
2000siturboR
Jun 2, 2008 08:09 PM
big juan
Oct 29, 2005 06:59 AM
Tripz
May 6, 2002 06:04 PM
Brian_92GSR
Oct 25, 2001 11:27 AM
