???can u adjust the boost from the wastegate???
Old Sep 26, 2005 | 12:25 PM
mkinpwrat12g's's Avatar
Default ???can u adjust the boost from the wastegate???
i was just wondering because i installed mine today. i hooked it up to the vacuum line on the fmu, are they supposed to be loud are not. i can not really hear mine at all. it kinda sounds like a girl sneezing. and i can hear the wastegate over it as well. and im only running 4 pounds. is there a way to adjust the wastegate to run higher boost?
Old Sep 26, 2005 | 12:30 PM
Default Re: ???can u adjust the boost from the wastegate??? (blackpearlej8)
bump
Old Sep 26, 2005 | 12:33 PM
White Smoke's Avatar
i my honda
Global Mod
You should have the top port open to air and the bottom going to vacuum.
What kind of WG do you have? No way to adjust boost unless you change the spring or go with a controller.
Old Sep 26, 2005 | 12:39 PM
Default Re: ???can u adjust the boost from the wastegate??? (White Smoke)
well my gage reads 4 pounds at full throttle. its a d16 y8 with the greddy 16g kit and, fmu, 240 injectors, and a front mount. is there a reason its at 4 pounds, my vacuum is reading at 20 at idle. does this sound normal
Old Sep 26, 2005 | 02:11 PM
nfn15037's Avatar
Greddy kits don't have external wastegates (hence, no top port). I think you have wastegate and blowoff valve confused. Sort that out and get back to us.
Old Sep 26, 2005 | 05:47 PM
Default Re: ???can u adjust the boost from the wastegate??? (nfn15037)
i have a internal wastegate. those words never came out my mouth.someone just told asked me what my wastegate was set at thats why i asked if i can control boost through my wastegate.
diputs
Apr 13, 2004 06:35 PM
highmilehatch
Oct 15, 2003 07:44 AM
1tyme
Apr 6, 2003 05:47 PM
blu_si
Oct 1, 2002 04:20 PM
_Endless_
Sep 23, 2002 10:00 PM
