can a turbo's specs be changed ?
Old Jun 28, 2001 | 06:13 PM
Purelude's Avatar
Default can a turbo's specs be changed ?
i don't know what specifics i have on my t3/t4 turbo, but if i got it rebuilt, can i also change the specs to suit my needs better? bigger/smaller wheels, the a/r,i don't know what i'm talking about really, just that i'll need a turbo better suited for my car since i got this one i have used and it might not be the right one for me.
Old Jun 28, 2001 | 06:16 PM
Jared's Avatar
Default Re: can a turbo's specs be changed ? (Purelude)
Yes, just tell whoever rebuilds it what you need(bigger/smaller wheel, bigger smaller housing, etc..) You can even change the center section, so if your turbo is only oil cooled, you can change to water cooled.
good luck,
Jared
Old Jun 28, 2001 | 08:17 PM
mike2016's Avatar
New User
Default Re: can a turbo's specs be changed ? (Jared)
how does a water cooler turbo work?? does it use the coolant from your radiator?
Old Jun 28, 2001 | 08:35 PM
LudeSi-93's Avatar
New User
Default Re: can a turbo's specs be changed ? (mike2016)
A turbo that is water-cooled is awesome! A water-cooled turbo runs coolant through it to cool it down. Water-cooled turbos will operate at lower temperatures and prevent coking of oil. It will also prolong the life of the turbo. Mine is water-cooled, and I just use the lines I disconnected from the coolant going through my throttle body. So, hot coolant won't run through my throttle body (coolant bypass), and then have those lines cool down the turbo. No major mods involved. Pretty cool, huh?
Old Jun 28, 2001 | 09:08 PM
mike2016's Avatar
New User
Default Re: can a turbo's specs be changed ? (TurboLudeSi)
How much it runs for a water-cooled turbo upgrade??
Old Jun 28, 2001 | 09:20 PM
LudeSi-93's Avatar
New User
You have to just change the center housing. Probably not too expensive, if you can take your turbo apart and put it back together. If you send it to them to do it, it will cost a lot more.
Old Jun 28, 2001 | 10:08 PM
mike2016's Avatar
New User
Mine has a full ball bearing stage 3 upgrade, does it mean it'll cost even more??
Old Jun 28, 2001 | 10:18 PM
LudeSi-93's Avatar
New User
I'm not really sure about that. I just have a straight T3 60 trim. But call up this place http://64.225.76.178/main.htm they have great pricing and a lot of info. I got a few of my stuff there. good luck
95BoostedEJ1
Feb 22, 2009 08:15 AM
This One
Jan 14, 2004 06:06 PM
You_Get_Vapors
May 4, 2003 06:17 PM
oldguy
Mar 2, 2003 08:30 AM
whagkangmakulet
Nov 21, 2001 03:04 PM
