can someone explain to me how these turbos differ from one another
the first 2 are the same pt stands for PRECISION TURBO. the gt35/67 is a gt35r exhuast wheel with a 67mm compressor wheel i believe. it is also ball bearing
ya i know, im asking what the difference between thes turbos are. cause all of them use the 35r wheel and a 67 inducer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">the first 2 are the same pt stands for PRECISION TURBO. the gt35/67 is a gt35r exhuast wheel with a 67mm compressor wheel i believe. it is also ball bearing</TD></TR></TABLE> there are GT series turbos that aren't ball bearing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtysohc »</TD></TR><TR><TD CLASS="quote"> there are GT series turbos that aren't ball bearing
But not the GT3567, not that I have seen anyway.
</TD></TR></TABLE>But not the GT3567, not that I have seen anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight »</TD></TR><TR><TD CLASS="quote">But not the GT3567, not that I have seen anyway.</TD></TR></TABLE> you're right, im not finding anything on a journal bearing GT3567...oh well, at least I can admit when im mistaken. I suppose I was just thinking of the GT3582 and GT3571 ersumshit
Modified by drtysohc at 11:25 PM 10/6/2006
p-trim is a T series wheel, it's older than the newer GT series wheels. A p-trim wheel has an inducer of 64.66mm and exducer of 74.22mm and the GT35R turbine is 68mm and 62mm.
GT35R turbine:
Can't find a P-Trim map.
GT35R turbine:
spoolin turbo s
Aug 27, 2008 10:19 PM
