Can someone check out my plugs and tell what they say???
Hey guys, I just pulled my plugs to take a look, fuel pressure is a little low at 30, just wondering what the plugs are telling me. Thanks.
Re: Can someone check out my plugs and tell what they say??? (allicedout)
my crystal ball says..........
they look lean
fuel pressure should be like 48
they look lean
I assume you pulled these after you let the car idle? Do a pull. Turn the car during the pull. Then take pictures of the plugs. The plugs are going to show the last combustion event(s). Do you have a wideband?
Re: Can someone check out my plugs and tell what they say??? (alpha)
the car definatly runs really rich at some point (hopefully in boost ). the base of the plug is covered in soot as is the insulator. The heat range looks good for the setup. cat really tell anymore on such a usd plug. put in new ones and shut it down at full boost.
Re: Can someone check out my plugs and tell what they say??? (Bailhatch)
he forgot to mention, he's boosted.
it almost looks like your car will run rich then go to lean being that your insulator is white as hell.
as already said. your fuel pressure should be around 45-50psi. get a wideband, see what your AFR's are and report abck
Here's a site I bookmarked, comes in handy when checking plugs...
http://www.verrill.com/moto/se...t.htm
Yes the car had just been idling. I'll have to try it again, Im having issues with fuel, I don't seem to have any leaks, maybe i'll just turn the pressure up on the FPR. its an AEM, anyone know which way to turn?
Re: Can someone check out my plugs and tell what they say??? (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">They look normal to me if you just pulled them after the car had been sitting</TD></TR></TABLE>
Ding Ding
Ding Ding
