can i use this turbo?
Old Aug 22, 2002 | 09:10 AM
johnzm's Avatar
Default can i use this turbo?
pardon my ignorance, but im more into NA than FI and now that ive got a T04 turbo, im wondering if it is a feisable project to get it rebuilt and use it... im going to be running it either on a b16 or a b20 block. any opinions?
Old Aug 22, 2002 | 05:49 PM
johnzm's Avatar
Default Re: can i use this turbo? (johnzm)
guys come on, this is a simple ustion. cant someone help me out here
Old Aug 22, 2002 | 07:02 PM
TheIntegraGuy's Avatar
You can use it..But the expensive part of turbo isnt the turbo...its the manifold, lines, fittings, charge pipes..internals...and to my best knowledge, and probably everyone elses...TUNING.... Just be careful if you're new to FI....
Old Aug 22, 2002 | 09:29 PM
johnzm's Avatar
Default Re: can i use this turbo? (SiDESLiDE240)
i appreciate u telling whats up, can anyone tel me about when this thing will hit boost on a 1.6?> is this gonna be a 5 grand boost hit or a 3800-4 grand?
Old Aug 22, 2002 | 10:21 PM
I think much much lower than that...Maybe youll hit FULL boost at 3000-4000 rpms...I'm not sure..so dont mark my word on that. Depending on what else you have, you might hit boost even sooner...
Come on guys..help him out!
Old Aug 22, 2002 | 10:42 PM
IntegD's Avatar
New User
Dude..if its a full t04, then you probably arent gonna hit boost till at least 5k. Hell, Justin(blkDOHCsol) doesnt make full boost until around 4k with his t3/to4b. Just imagine a t4 turbine and compressor. What size are the housings??
Old Aug 23, 2002 | 05:05 AM
RGAZ's Avatar
New User
Default Re: can i use this turbo? (IntegD)
Yeah what he said, we need ar and trim numbers to estimate when the boost will hit.
Hell even with a b20 I bet you won't see boost until 4500 rpm.
Randy
Old Aug 23, 2002 | 05:49 AM
Charlie Moua's Avatar
T04... hum can't remember that well but that sould be almost like the T25(some one correct me if i'm wrong) wait a minute what car is that turbo from?
anywho... that turbo should work well with a B16 or B20, but will spool much mor faste with the B20 that's for sure. Rebuilding it sucks, never did it but i'm guessing you would just send it into some company that re-builds it. Shouldn't be too bad on the wallet.
Old Aug 23, 2002 | 07:22 AM
johnzm's Avatar
Default Re: can i use this turbo? (Charlie)
i only found one # on the exhaust housinf A/R .69 can someone clue me into what this means for power/lag wise?> and yes, its a full T04
Old Aug 23, 2002 | 07:34 AM
Ri5e's Avatar
I can make full 1 Bar @ 3,800-4,000 RPM with me T3/T4e
Old Aug 23, 2002 | 04:59 PM
johnzm's Avatar
can someone tell me what a .69 A/R is? thats th eonly # on the turboi i can find
Old Aug 23, 2002 | 05:47 PM
johnzm's Avatar
come on i know u guys arent stupid. help me out here
Old Aug 23, 2002 | 06:44 PM
TurbothisLS's Avatar
i'm going to be running a T04 as soon as it comes in (should be this week)
From what I know, this is a pretty big turbo and it will take it a while to spool up
I'm still looking at manifolds, but new = $900 or $525 for a race manifold w/ no a/c
i still dunno about it...
Old Aug 23, 2002 | 07:44 PM
johnzm's Avatar
Default Re: can i use this turbo? (TurbothisLS)
i appreciate your reply, i am getting a custom manifld made if i decide to use this thing so room/lack therof isint a big issue for me, even tho im going to be running it in an EF
Old Aug 23, 2002 | 08:01 PM
ekb18c's Avatar
T04 wont spool till 5-6k on a small displacement motor. That .69 is your aspect ratio. Where does it say .69 a/r ? On yoru compressor or exhaust housing?
Old Aug 23, 2002 | 08:12 PM
Smashback's Avatar
http://www.turbonetics.com
http://www.homemadeturbo.com
http://www.dsm.org
http://www.google.com
There is tons of info out there. I would not recommend installing a turbo until you at least have some clue about them.
Old Aug 23, 2002 | 08:18 PM
johnzm's Avatar
Default Re: can i use this turbo? (ekb18c)
on the exhaust housing
Old Aug 23, 2002 | 08:26 PM
ekb18c's Avatar
So yeah, it's a late spooler! Look for it to spool at 5k! Not really worth if it your going to boost 7-8 psi, your better off with a t3/t4oe
Old Aug 23, 2002 | 09:03 PM
johnzm's Avatar
what do u think, if i raise my redline up, will other things dictate the power curve other than this turbo? if it spools at 5k it should be able to provide alot of CFM through 9k right? will that make the motor keep gaining power past 8k or will the cams bring the fun to an end early? BTW is there any way this can be made into a hybrid turbo to reduce spool time?
rEnZ94tEgGy
Nov 15, 2008 06:12 PM
turbo boost
Jun 26, 2008 07:19 PM
ctr83
Mar 21, 2008 02:41 PM
E. Honda
Jun 18, 2002 02:56 PM
