Can i run nitrous w/ one solenoid, fogger, jet, lines and 10lb bottle?
B A N N E D
What the topic says. Or do i need more because I am working on a tight budget.
Re: Can i run nitrous w/ one solenoid, fogger, jet, lines and 10lb bottle? (kaoss_11)
How are you adding fuel. If you got the fuel covered, you can run with what you got. If not, boom biotch
Location: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Re: (kaoss_11)
yes u can if u are running a simple small dry shot.
if u have no other means of fuel management (at least) raise fuel pressure..
single nozzle kits like that are a recipe for disater, will it work.......sorta, will you feel nervous....hell yeah. i have seen all the valves in a honda head melt this way,
people use to do this wayyyyyyyy back in the day. you need some way to properly mix the correct amount of fuel and nitrous.
just get a solinoid from ebay they should belike 40 bux, get the jets, like 6 bux a piece, and a piece of line 12 bux.
B A N N E D
well my fuel manegment is hondata s200, 450 injectors, aem fpr, msd inline fuel pump, golden eagle fuel rail, and a/f meter guys still think i should get another solenoid
Re: (kaoss_11)
with hondata s200 you can ad fuel when running nitrous. so you don't need fuel enrichments actions. just make sure you ad enough fuel with hondata
94redhatchbackNYC
08-21-2007 05:44 PM
