can i run 10lbs???
ok finished peiceing my turbo kit together ... (waiting for all peices to arrive) ... gonna do RC440 injectors.. and the hack.. can i run 10'bs of boost using this setup?
Re: can i run 10lbs??? (queez)
thats a little vague, tell us your set up, engine specs...bla bla bla
Re: can i run 10lbs??? (ridnmyhonda)
ok.. building a custom setup.. very similar to rev hard 2c kit... i talked to the guys at revhard and they said a b16a2 stock can run up to 14psi without damage. and like 11-12 psi daily no problem..(any one doing this???)
my setup t3/t04e .57 trim .63 a/r revhard steel (w/ac) mani revhard 2.5" downpipe spearco fmic (core) 20x8x3 tial 35mm wastegate with .65 bar 2.5" chargepipes blitz bov warlboro 255lph pump RC 440 injectors vafc avcr victor x intake mani k just wondering if 10lbs with the hack is ok.. can the hack handle 10lbs with this setup>?? [Modified by queez, 8:15 PM 3/10/2003] |
I run about 11psi daily on my b16, running the afc hack with a btm.
Re: can i run 10lbs??? (turbosol)
how much boost did you run to get 283whp, i don't know what .8 bar is https://honda-tech.com/forums/images...s/emhammer.gif on me
Re: can i run 10lbs??? (93dx--hatch)
how much boost did you run to get 283whp, i don't know what .8 bar is https://honda-tech.com/forums/images...s/emhammer.gif on me |
Re: can i run 10lbs??? (kenbdSi)
I'm running 8.5lbs on my stock B16A2 and that is as far as i want to push it. I know alot of people say 10lbs is fine or maybe even more, but when you almost double your HP how much more can the motor really take? I have seen many motors blow at 8-10lbs and if it doesn't i think you are really reducing the life of the motor. Just my .02 cents.
Re: can i run 10lbs??? (simike)
I'm running 8.5lbs on my stock B16A2 and that is as far as i want to push it. I know alot of people say 10lbs is fine or maybe even more, but when you almost double your HP how much more can the motor really take? I have seen many motors blow at 8-10lbs and if it doesn't i think you are really reducing the life of the motor. Just my .02 cents. |
Re: can i run 10lbs??? (boostedsol)
Get a wideband o2 and make sure your air/fuel is good. I'm sure you can run 10psi daily on stock internals.
Re: can i run 10lbs??? (BoostedSi)
I'm not worried about tuning, i'm worried about the actual strength of the piston rings/lands under the higher cylinder pressure. I have seen alot of them crack and i don't think tuning has to do with that. If there is a hole in the piston or it has melted i would say you needed to tune it better. I may be wrong, but that is how i see it.
I'm running 10psi on my GSR motor with a SMC and 450s. Its putting down 330whp. As stated above, wideband is the key. You can't guesstimate when your running that close to the edge. Good gas also, I wouldn't run 10psi if all you can get is 91 octane.
