Can I run 10 lbs. of boost with this SOHC setup?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
d16y8
eagle rods
JE pistons (not sure on compression)
blockguard
V-AFC w/missing link, 12:1 FMU, DSM 450's, walbro 255lph, whatever else I need
ACT HDSS clutch w/ fidanza or CM flywheel
HKS Hiper 2.5" cat-back exhaust
What I'm wondering is can the V-AFC handle this kind of setup?
eagle rods
blockguard
Re: Can I run 10 lbs. of boost with this SOHC setup? (MatT3T4)
I see you said "ran", as in the past tense. Did it blow up?
Re: Can I run 10 lbs. of boost with this SOHC setup? (fnananon)
d16y8
eagle rods
blockguard
eagle rods
blockguard
Only after 6 miles of redline pegging at 145mph...
But besides that, it was fine. I blew it because I felt like being an *******. Other than that, you'll be fine, the V-AFC can do that.
Re: Can I run 10 lbs. of boost with this SOHC setup? (b16ahybrid)
Yeah but we all know that your crazy
The doctor says that there is nothing wrong with me...??
you'll be fine, ditch the FMU and you dont really need the fuel pump either. oh yea and you dont need a missing link with the afc setup at 10psi.
I run 10psi all the time on my stock Y8 with just V-AFC and 450's. stock fuel pump and it works great.
Re: Can I run 10 lbs. of boost with this SOHC setup? (CrX1988Zc)
I'm running 8-10lbs of boost daily on completely stock Y8 internals. I'm running DSM 450s and an AFC.
Re: Can I run 10 lbs. of boost with this SOHC setup? (inspyral)
i hope to have my turbo put in sometime in summer 03' hopefully rev hard will have their kit released or atleast their manifold
Re: Can I run 10 lbs. of boost with this SOHC setup? (aznmikex215)
Man you should be looking at 10 psi + with your set up.
Like the guy's said ditch the fmu and missing link, you won't need it running the afc hack. Sell that and spend the money on a boost controler. A boost controler on a sohc is a must to increase the spool up and and increase the wham bam when the turbo kicks in.
over 11psi you will have to swap the map sensor with a gm 3bar, and a fuel pump (which you have, unless its an inline) would be recommended. I would say try for 14psi.
Best of luck and let us know how it turns out, sounds like you got potential for a sick soch setup bud.
[Modified by Hybrid, 11:52 PM 11/17/2002]
If you can supply your a/f ratios, egts, and timing under boost, I can intelligently answer your question.
At least a/f's and base timing would help.
Thanks and good luck
Re: Can I run 10 lbs. of boost with this SOHC setup? (Speedworks801)
Get Hondata don't **** around with shitty hacks and other such crap you obviously are trying to get a decent setup there, get hondata first you can boost 10psi easily I wouldn't do it everyday though... Then get the aftermarket rod's and pistons and run some real boost through it..
Re: Can I run 10 lbs. of boost with this SOHC setup? (turbozxi)
I would say **** the afc hack and save up for a hondata. I fully built my d16 and all I have to show for it is 10psi.....cant go much higher without some other type of management....10psi is fun but it is not what I was expecting. 15-20psi, now that sounds fun. My motor is ready for it, just need to save up for the hondata....
syiracing
10-26-2004 07:15 PM
