Bolt broken from LCA
This bolt holds the LCA to the trailing arm. I tried to drill a hole in it after I used a center-punch but I made the drillbit dull by drilling fast! The next day, I found out that I needed to go slow while drilling.
The bolt basically broke like this drawing I did. Only one metal area(?) is being supported by the bolt. I had a friend push my car downwards repeatedly and the one that isn't supported by the bolt is flexing down and up.
My question is, is it safe to drive? I need to get to school!
The Grumpiest
Re: Bolt broken from LCA
See that black part? You have to cut that part off. Then get a proper sized nut to use on the new bolt. Ask me how I know.
Or cut the bolt on the other side of the trailing arm so you can remove it. That's where mine broke. That still leaves you with the end of the bolt that you PRAY isn't seized up in that welded nut.
Dude, school is important but, not that important! Don't drive it!!!!!
The time it took you to make that cool drawing of the issue you could have drilled it out and slapped another bolt in.
i didn't want to deal with it and let mine go for a few months. it WILL go out eventually -_-
If i had fixed it before i could have atleast saved a tire and the scary experience, no doubt with the amount of rust i would had to replace the lca anyway.
I have the same coilovers. I bought their LCA too and wanted to replace mine, but because of this bolt I can't put my LCA on... and..... The bushing on the LCA is too wide for the shocks fork(?) how does happen? Lol it's the same brand too...
Or maybe I'm missing a step here...
I spent 80 dollars in drill bits and a drill doctor when I snapped one of mine.... I ended up throwing in the towl and bought a new lca and strut assemply lol
There's no reason to spend that much money. Undo the other bolts, take the assembly out, bring it to your local machine shop, and have them drill the bolt out for you.
I had done that too... the machine shop toasted my bushing... that was my excuse for buying new LCA's :-)
Resident Gearhead
I've spent HOURS drilling these out, that **** is no fun at all. A Drill Dr is almost a necessity for this job.
Sometimes you do have to drill them out to get the car back on the road, but Honda does sell the rear LCA
with bushings installed for about $65 (Majestic Honda)
Seagull Management
That's a '96 - '00 Shock, the control arm looks bushing is for a '92 - '95 or Integra. Besides not fitting the shock fork it should also be the wrong length for the car.
I got an email saying there were a batch of EK LCA with the wrong bushing and I got one of them. I'll get a shipping label and ship it back and get a correct set.
(long story short, my buddy Zach got it out with a drill lol)
Back to the broken bolt. Zach tried different things to get it out. He first grinded down the pointy end of the stud flat and welded a nut to it, but the bolt would just brake off. He grinded the welded nut that's attach to the trailing arm and was able to pull the LCA off loose. He tried hammering it out with a sledge hammer and then the back of an axe for more power! It wouldn't move anywhere and then he grinded 2 sides of the stud flat so he could put pliers on it and tried twisting it, but the bushing would twist with it. HE then torch it and hammer and torch it and hammer. Zach managed to get it out with hours of drilling
yea uhhh not a good idea 2 drive on that lol.......kinda important to have that bolted in bro......ur learning tho......HONDA-TECH jus stopped a potental crash lol good job
