can i boost a high compression engine
Old Mar 12, 2013 | 08:11 AM
urie2324's Avatar
Default can i boost a high compression engine
hi im building a b16 vtec 1.6 with reinforced pistons, rods and a original crankshaft ( which from my research it holds up to 800 hp) the pistons I got are for high compression so my question is can I turbo the engine with out blowing the motor and if its possible what else do i need to be able to boost my engine any help if very well appreciated
Old Mar 12, 2013 | 08:20 AM
Schister66's Avatar
Man U FTW
Default Re: can i boost a high compression engine
What is the compression ratio? Are the pistons forged or cast? Brand? Which rods?
Its easy to tell from your original post that you need to do more research. Read the FAQ at the top of the forum before posting questions. Turbo setups aren't the kind of the thing you can just 'jump' into blindly
Old Mar 12, 2013 | 11:47 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I don't know, can YOU boost a high compression engine?
I know for a fact that I can...
Old Mar 12, 2013 | 11:50 AM
SovXietday's Avatar
This is one of those things where if you have to ask the question, then you can't.
Old Mar 12, 2013 | 11:56 AM
wantboost's Avatar
Who is Mr Robot?
Nope never been done....
urie2324
Mar 13, 2013 10:24 PM
trytomake
Dec 8, 2008 11:30 AM
RTst92
Mar 5, 2006 01:56 PM
OoDepriveDoO
11
Jul 23, 2003 11:33 AM
lliew
Sep 13, 2001 05:26 AM
