Can I Boost
Old Jan 15, 2007 | 09:58 AM
vbherrera's Avatar
Default Can I Boost
I want to know if i can go boost.. i want to make sure it will be safe, and if so about how much boost?
My Current N/A Set up
b18a
line bored
bored and honed .75 over
bored coolant passages
machined crank journals
machined rod journals
micropolished crank
arp rod bolts
shot peened rods
pr3 pistons
new bearings
itr water pump
itr oil pump
itr head
port & polished head
gsr cams
ferrea valve train
skunk2 intake manifold
injen intake
b16 tranny w/lsd
act heavy duty pressure plate
act street/strip disc
act lightened flywheel
handata s200
Old Jan 15, 2007 | 10:10 AM
93supercoupe's Avatar
Default Re: Can I Boost (vbherrera)
No, u CANNOT TURBO THIS ENGINE!!!!
once that turbo is bolted to the manifold, its likely to not even start.
Old Jan 15, 2007 | 10:19 AM
PrecisionH23a's Avatar
Why are you throwing in all OEM parts for a turbo build?
Old Jan 15, 2007 | 10:27 AM
vbherrera's Avatar
Well i did not build this engine for turbo.. i built it for N/A... but i am seeking more power and want to see if boost was an option...
Old Jan 15, 2007 | 10:31 AM
Default Re: (vbherrera)
Boost is always an option. Since you have it apart I would recommend replacing the rods and pistons though.
allmotor-teg
Mar 6, 2014 10:23 AM
JZs15
Feb 26, 2009 03:21 PM
ek-j
12
Jul 28, 2008 08:04 PM
sivtc99
Apr 6, 2006 08:54 AM
sloef
Aug 15, 2002 11:33 PM
