how much boost on this set up?
Old Aug 15, 2002 | 04:39 PM
sloef's Avatar
Default how much boost on this set up?
i tried the search and i also read a lot of posts.....
b16 2nd. gen head ,pocket port/polish and port match w/itr manifold
ferrea valvetrain (ss valves,dual springs,ti ret.)
1 mm. oversized intake/exhaust valves
ctr cams
b18a bottom with 20 over je 9:1 slugs
crower billet rods w/ arp bolts
bal/knife edge b18a crank gsr crank bolts (gsr oil pump,b16 waterpump)
inlinepro head gasket /arp head bolts
i want to go turbo with this set up and will be runing a mits. tdo6-20g(modified tdo5-18g) greddy i.c. int. gated with profec b
this is in a 91 civic si with secu gold zydne (450's cc.will go 720's depending on boost) 255.lph intank pump
what levels of boost can i run (provided the tuning is good) without problems to the motor. i plan on about 260-300whp unless i can do more ,which i think i can. the question.-------------Can this be done with a blockguard?????? since i've spent all my money. any advice will help. thanks
Old Aug 15, 2002 | 04:42 PM
AlphaKennyWun's Avatar
Default Re: how much boost on this set up? (sloef)
15 lbs on pump gas
22 lbs on race gas
Old Aug 15, 2002 | 05:10 PM
Pinhead's Avatar
New User
Default Re: how much boost on this set up? (SO3Burner)
that much on stock sleeves????
Old Aug 15, 2002 | 09:22 PM
sloef's Avatar
Default Re: how much boost on this set up? (Pinhead)
thanks for the reply,yeah how much on the stock sleeves?. i was thinking maybe 14-16 lbs. max ? any ideas......thanks.
Old Aug 15, 2002 | 11:33 PM
*Boostwerks*'s Avatar
with tuning.....go as high as you want.
...On pump gas for the street I would stay around 15psi.... Anyways....you cant really put down anymore power through street tires even at 10psi!!!
Keep the boost low for the street....then boost the hell out of it at the track.
denraweb
Feb 6, 2008 02:04 PM
kydragger
Feb 16, 2007 08:37 AM
vbherrera
Jan 15, 2007 10:31 AM
JDM97EK
Dec 18, 2006 02:31 PM
