can boost controllers prevent boost creep?
Old Sep 12, 2001 | 11:56 PM
SIK IN DA HED's Avatar
New User
Default can boost controllers prevent boost creep?
do boost controllers prevent boost creep?
i was thinkin about gettin a manual boost controller. i was wonderin if it would prevent boost creep on my deltagate. heard lots of stories about boost creep on those wastegates. i cant even boost a steady 7lbs on my wastegate. i dont wanna take a chance and keep adjusting it. spring might give way and BLAM! there goes boost creep on that ***.
manual controllers also hold boost pressures alot better than just the wastegate alone rite? cuz i know electronic boost controllers help prevent boost "leaks".
Old Sep 13, 2001 | 02:44 AM
JM Performance's Avatar
Default Re: can boost controllers prevent boost creep? (dlplayboy)
I'm not positive, but I think a manual boost controller wouldn't do anything. Cuz it still depends on your deltagate spring to reliese the pressure.
Just pick up a tial wg for like 250 and save yourself the trouble. Its 250 that could save your engine.
Old Sep 13, 2001 | 03:16 AM
The Punisher's Avatar
Default Re: can boost controllers prevent boost creep? (00SilverLS)
Actually a MBC will help! The spring is there if you don't have a boost controller. That way he can run 7 psi, no more, no less. Do you have a boost gauge? Just make sure you aren't using a "BLEEDER" type MBC, they suck! If you do a search, you will see some posts about making your own MBC, and if that is not your thing, there is also a post for a MBC for around $50. It is good, and will work fine in your application. Everyone I know is using a delta right now with a MBC, and they are not having any creep problems at all.
zccr-xsi
Mar 22, 2006 06:26 PM
c61lude
Jan 19, 2006 04:34 PM
echo999
Oct 3, 2002 07:41 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
