Can adjusting my TPS sensor lean out? how can I lean out my system?
Old 06-10-2003, 02:41 AM
Sinner's Avatar
Default Can adjusting my TPS sensor lean out? how can I lean out my system?
someone said that if your tps sensor is not set to .45 volts that it could raise your fuel curve. I'm running sticking rich bad. What can I do to lower it? Will turning the distributor lean it out?
btw I have d16z6 with 450cc's controlled by a fields controler at -30 straight across and thats the max - it will go. I hate to have to get new injectors but I will if thats the only way.
Nick
Old 06-10-2003, 03:48 AM
h22 ef's Avatar
Default Re: Can adjusting my TPS sensor lean out? how can I lean out my system? (Sinner)
your injectors are to big, stock computer cant control injectors over 370, even with a vafc or the fields, get hondata or different injectors
Old 06-10-2003, 09:52 AM
New User
psileepR's Avatar
looks like your fields can lean out your injectors enough to run...
450cc injectors on a boosted D series usually need to be trimmed 35%-40%
ps. if u are turbo'd then turning up the boost will lean it out
Old 06-10-2003, 09:56 AM
kpt4321's Avatar
Stock injectors are 270 cc/min, right? If you put 450's in place of 270's, you will need close to -40% correction, and certainly more than -30%.
How rich are you? How are you measuring this?
Increasing the boost will not necessarily lean it out, unless the injectors are maxed out, or you have some sort of hacking of the MAP signal that's causing it to flatline after a set boost level. Otherwise, fuel flow will increase with airflow like it should.
Old 06-10-2003, 11:30 AM
GreddySi99's Avatar
Default Re: (kpt4321)
who the **** said you can only run 370's on the stock ECU 240's 270's and 310's are fine unless you have a way to control them. A vafc can control 440's and dont say it wont because I have been running this setup for a year now
Old 06-10-2003, 11:32 AM
t04s's Avatar
Default Re: Can adjusting my TPS sensor lean out? how can I lean out my system? (h22 ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 ef &raquo;</TD></TR><TR><TD CLASS="quote">your injectors are to big, stock computer cant control injectors over 370, even with a vafc or the fields, get hondata or different injectors</TD></TR></TABLE>
duh.....
HondaKid936
11-13-2008 07:16 AM
russianswty
27
11-14-2006 06:30 PM
LuderCriS
07-26-2005 02:37 AM
B17aTrbo
09-16-2002 08:12 PM
KevronsEG
08-13-2002 07:34 PM
Quick Reply: Can adjusting my TPS sensor lean out? how can I lean out my system?
