Cams, Valvetrain & headwork
Hi guys, I need some urgent help. To most who probably will not remember any of my previous posts, I am from South Africa & own a b16a vtec, 4 door Civic sedan, 1999 model, which I am in the process boosting. My goal is around 450whp & I want to rev to 10000rpm, realistically 9500.
These are my engine components:
Precision SC32 turbo
880cc Precision injectors
GReddy dumpvalve
Tial Wastegate
Wiseco Pistons
Eagle rods
ARP's
AEM fuel rail
Walbro 255lph
Custom intake
GSR girdle, sump, pickup, etc...
Posted block
ACL race bearings
Snow performance boost cooler
Cometic headgasket (I may stick with the stock Honda one)
Ingalls damper
Avid mounts
STR cam gears
Gotech mini X management
manual boost controller
There is probably more that I can't remember right now.
I have some questions that I need URGENT answers to:
My first question is what cams & valvetrain to achieve my goal? I currently have GSR cams, & I was offered a Z-Speed/Toser valvetrain at a good price (40.9/19.5mm. 2.65kg/mm, free length/coil bind?) Perhaps Skunk Pro 1, or Buddy Club Stage 1 (the equivalent of the Pro 1)?
The other question is that I recently overhauled the head, but I was wondering if I should have done some headwork? Is it neccessary as I was told that it would only result in negligible gains. Without the headwork, I would still achieve my target. My problem is that I was told the headwork needs to be done in a particular manner, or it my result in power loss if done incorrectly. Locally, Hondas are not wildly popular, so engineers may not have the neccessary info on what needs to be done. The other problem is that I will have to buy another set of valve stem seals, seeing as the head has already been done.
I look forward to all of the valuable knowledge you guys have to impart.
GReddy dumpvalve
Tial Wastegate
Wiseco Pistons
Eagle rods
ARP's
AEM fuel rail
Walbro 255lph
Custom intake
Posted block
ACL race bearings
Ingalls damper
Avid mounts
STR cam gears
I would do a ported head with supertech valvetrain if you plan to rev that high. I have both just to be on the safe side. For cams, I would say ITR or Blox B. ITR is a favorite to many on here, how ever blox b's are becoming more known now and have been prooven to make good power at low boost
are u goin on the breakie run?why dont u pm riaan on hrc,im goin with pro 1and supertech everything else,why dont u look at crower,or rocket(not sure if that is the name) and give sac a call,sometimes the do great work
Getting ITR cams locally will cost just about the same as getting Skunks or Blox, so maybe those rather. Any other opinions, cams, valvetrain & headdwork?
Junaid - for 400whp you'll max out the SC32 ( I personally think its abit small for your overall goal with the car)
On 400 whp cams wont make a huge difference - GSR's will get you there
gringotegra
Oct 20, 2020 04:04 PM
sdime94
Dec 22, 2012 11:01 PM
