Cams?
Old Oct 2, 2002 | 12:58 AM
The sweed's Avatar
Default Cams?
Any one have a better ide of what brand of cams I should use? I plane to use CTR cams on my boosted b16.
Iīll be useing camgears ofcaurse. 64mm TB, Golden eagelīs intakemani (same as str and also venom I think) and fierra valves, endynīs 84,5 mm RW pistons and a equal length turbo mani. Letīs say 20-25 psi too
Old Oct 2, 2002 | 06:26 AM
bruthaboost's Avatar
Default Re: Cams? (The sweed)
Though high lift is nice for a large curtain volume, ctr cams have quite a bit of overlap. Why did you pick ctr cams?
Old Oct 2, 2002 | 11:17 PM
The sweed's Avatar
Default Re: Cams? (bruthaboost)
I was recomended them on endynīs bbs. Somebody said that itīs as sharp as u can go with turbo. Iguess u can dail out the overlap with camgears.
What should I go with?
Old Oct 3, 2002 | 03:39 AM
The sweed's Avatar
Iīve did a search but no one realy recomand a set of cams accept the stock or GSR with low boost. I want it for high boost. But it seems like aftermarket cams donīt offer as much more power. crower seem to have good cams but itīs not worth the risk if they break.
NO ONE!!!?
Old Oct 3, 2002 | 08:27 AM
PrecisionH23a's Avatar
a lot of turbo gsr's run stock gsr camshafts. if you are going to replace the stock ones, i recommend going with a camshaft made for a turbo application. I know GUDE offers these...
FSUseminoleEM1
Feb 6, 2009 12:54 PM
BEV@GSCMotorsports
Sep 1, 2004 06:42 PM
2k1 GSR
Mar 3, 2003 09:27 AM
VRxDReGoNxGSR
Jul 15, 2001 10:16 PM
