Are GSR cams better than b16 for turbo?
Re: Are GSR cams better than b16 for turbo? (CivicTurbo12)
YES! Thats what I did; Well in the process of doing.
(I cant remember why; but I think it has to do with the lift. Im sure someone can pull the facts out!)
Re: Are GSR cams better than b16 for turbo? (rocket256)
how are web turbo cams or any other turbo cam compared to stock cams? what makes them better also?
Re: (Sound Streamin')
skunk2 cams are going to be expensive; I picked my gsr ones up for 80 bucks. ctr and itry cams arent good for boost because those cams are designed to make compression. You want a good flowing cam with high lift (i think). Until i can afford some turbo designed cams I figured the gsr ones were a good pick up
Re: (jdmjerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk »</TD></TR><TR><TD CLASS="quote">skunk2 cams are going to be expensive; I picked my gsr ones up for 80 bucks. ctr and itry cams arent good for boost because those cams are designed to make compression. You want a good flowing cam with high lift (i think). Until i can afford some turbo designed cams I figured the gsr ones were a good pick up </TD></TR></TABLE>
There's guys make crazy hp with itr and ctr cams too!!!
Re: (blacksi-t)
cam specs (which are correct)
Following cam measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Civic Si(1999 Spec)
Integra GS-R
Re: Are GSR cams better than b16 for turbo? (jdmjerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk »</TD></TR><TR><TD CLASS="quote">Im not understanding your dyno sheet? How it show its better </TD></TR></TABLE>
if you look REALLY REALLY REALLY close, you will notice the GSR cam line is above the other..
mike
mike
Hmmm I am like half asleep but there was a guy here with a 612 (i think) whp B16 and he used Type R cams and just with swaping the cams from B16 to Type R he gained something like 30 poneys.....but thats for high boost also...Dude just don't worry about cams unless your going for 400+ its a waste of money IMO for anything less...but hey to each there own. I personally am going to be running Type R cams in my high boost setup.
Re: Are GSR cams better than b16 for turbo? (Stickdeath)
island4drtyper, whats your setup? just wondering thats pretty good numbers, who did the dyno tuning ? I like the NEW facility you guyz moved to. In the vid. your car moves pretty good, maybe one of these weekends we can meet up at the track and run. By the way is that brian's car? anyways it's awesome looking.
Re: Are GSR cams better than b16 for turbo? (numba1)
if any one want to buy gsr cams and cam gears for 50 bucks let me know??? or IM me i just bought itr cams and my gsr cams are just going to collect dust.
Thanks numba1, the car is actually mine, Brian still has his 4dr.
It was dyno tuned by Autowave in Huntington Bch. Here's the link to my specs:
http://www.islandmotorsports.com/project_cars.htm
Re: (jdmjerk)
The ITR and CTR cams do NOT have too much duration for turbos, this is one massive myth. This is especially true on a vtec motor where the higher duration cams only kick in at higher RPM's, so overlap really isn't an issue.
Re: (boosted92)
so say you are planning on building the motor down the road but for now you are going to be running stock internals but boosting 10-12 PSI on a b16, would it make any difffernce to put in Gsr/itr cams??
or
just keep the stock cams
or
Re: Are GSR cams better than b16 for turbo? (island4drtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by island4drtypeR »</TD></TR><TR><TD CLASS="quote">GSR cams all the way! Check out my dyno sheet, before and after.
this is not a good comparision as there was obviously more variables than the cams. the graph shows way more power before vtec even crosses over which in my mind suggestd a bit more boost also
Re: (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">
The ITR and CTR cams do NOT have too much duration for turbos, this is one massive myth. This is especially true on a vtec motor where the higher duration cams only kick in at higher RPM's, so overlap really isn't an issue.</TD></TR></TABLE>
I wanted to put ctr and itr cams in my car; I was told not to by a load of people....I was always told they create compression which you dont want in a turboed motor.....
Im still sticking to GSR cams here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegon-gsr »</TD></TR><TR><TD CLASS="quote">if any one want to buy gsr cams and cam gears for 50 bucks let me know??? or IM me i just bought itr cams and my gsr cams are just going to collect dust.</TD></TR></TABLE>
DAMN that would have been a killer deal!
