cam timing
Old Jan 8, 2006 | 03:35 PM
raiden571's Avatar
Default cam timing
does anyone have dyno charts of there turbo setups where they actually gained or losed power by messing with cam timing?
Old Jan 8, 2006 | 04:41 PM
mtber's Avatar
Default Re: cam timing (raiden571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have dyno charts of there turbo setups where they actually gained or losed power by messing with cam timing?</TD></TR></TABLE>
Ls/vtec/turbo
Stock ls bottom end w/ gsr head on 9 lbs
Skunk2 intake manifold, Garett 57 trim .63 ar
Ended up with -4 on the exhaust cam and 0 on the intake cam.
Old Jan 8, 2006 | 08:19 PM
raiden571's Avatar
i was searching thru some old threads and someone said that cam timing on an b18 non-vtec worked best at 0-0. just wondering if people have had the same results with different cam setups
Old Jan 8, 2006 | 08:38 PM
mrbsponge's Avatar
each motor is unique with the millions of factors from one to the next, heads, blocks, milling, decking, cams etc
cam tuning will find power no doubt
Old Jan 8, 2006 | 09:06 PM
Tad's Avatar
Tad
Default Re: (mrbsponge)
yeah,
for a totally stock motor..
**** 0-0 is probably ur best bet.
but once you start running some crazier stuff,
hefty camlobes, better flowing everything(IM intake, ports) exhaust,
higher compression, blah blah blah
then yeah cam timing should definetely make a difference.
at least thats how my mind sees it.
Old Jan 9, 2006 | 06:07 AM
raiden571's Avatar
is it true that turbo cams (crower's for example) are actually ment to be at 0-0? or is that a myth?
hondafan62269
Jan 7, 2005 09:34 PM
radeon
Aug 6, 2004 08:10 PM
kefka
Apr 16, 2002 07:16 AM
