cam shaft installation
Old 07-30-2003, 09:56 AM
InTeGrA B18b1's Avatar
Default cam shaft installation
i recently pulled the head off for a blown head gasket...
and im not sure how to put the cam shaft back on.. i know if im off by alil my timing will be all wak and blow sumthing else...
i think u just put the piston at tdc and also the cam shaft... i just want to make sure if im right
Old 07-30-2003, 09:57 AM
Default Re: cam shaft installation (InTeGrA B18b1)
bump
Old 07-30-2003, 10:04 AM
toolowsol's Avatar
set the crank to TDC (there is a mark by the crank pulley also) then set both cam shafts (or one if you have sohc) to tdc as well, retention the belt, tighten the tentioner and your done.
ohsnapzafingcu
09-07-2006 01:03 PM
Muckman
09-22-2004 09:44 AM
donnjuan2point2
03-04-2004 04:40 PM
DC2R714
10-28-2002 02:12 PM
Quick Reply: cam shaft installation
