Cam gears+30 lbs question
Old Aug 30, 2006 | 03:51 PM
andysila's Avatar
Default Cam gears+30 lbs question
Right now on our hatch we have stock GSR cam gears.
we're running 30 lbs. fully built motor, twin disk clutch and what not.
i ahve a couple questions.
1- What significant difference did you see by getting aftermarket cam gears+ tuning them with your 30 LB setup?
2-On a scale from 1-10, how important are they?
thanks guys
Old Aug 30, 2006 | 04:36 PM
BB6-213's Avatar
I would like to know also. Are you running stock cams?
Old Aug 30, 2006 | 05:53 PM
Mugencrxsir1's Avatar
Default Re: (BB6-213)
I do know that if you buy aftermarket cam gears, and don't know what your doing you can lose a lot of HP. So my guess would be a few extra ponies with someone that knows what there doing.
Old Aug 30, 2006 | 10:24 PM
andysila's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know also. Are you running stock cams?</TD></TR></TABLE>
Yes, GSR cams.
this is the car.
Old Aug 31, 2006 | 06:55 AM
CivicVX94's Avatar
Default Re: (andysila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila &raquo;</TD></TR><TR><TD CLASS="quote">
WTF are the deminsions of that radiator?? that thing looks tiiiin...wow lol
either way bump
Old Aug 31, 2006 | 08:03 AM
adictionbass's Avatar
Default Re: (CivicVX94)
i think evans tunning did a comparison, but im too lazy to look for it
Old Aug 31, 2006 | 08:10 AM
B18C Turbo's Avatar
there are 2 portson your vacuum distribution block that are unuses are you getting vacuum leaks?
Old Aug 31, 2006 | 08:59 AM
sleeprhatch's Avatar
Default Re: (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo &raquo;</TD></TR><TR><TD CLASS="quote">there are 2 portson your vacuum distribution block that are unuses are you getting vacuum leaks?</TD></TR></TABLE> nope you have to drill those ports out to use them.
Old Aug 31, 2006 | 12:08 PM
SOUNDEFFECTS's Avatar
Default Re: (sleeprhatch)
From stock GSR cams to some aftermarket ones you will gain a SHITLOAD OF HP.
Cam gears on stock cams probably won't yield much if you ask me. Buy some ITR cams, Skunk stage 2 cams or some pro stage 2 cams, go big, leave gears at 0,0. Guarntee to make more power, if you still need more power then adjust gears but becareful.
TRYLSTEG808
Jul 24, 2007 02:00 PM
b16a4
Apr 1, 2007 05:17 AM
blkwidow420
Apr 14, 2005 01:37 AM
mrbsponge
May 30, 2004 06:15 PM
Try2Live4God
Jan 17, 2004 11:15 AM
