Cam gears?
Old Aug 30, 2009 | 07:04 AM
slowboy90's Avatar
Default Cam gears?
Anyone heard any good things on Vision cam gears?
also what kind of cam gears are you guys running?
Old Aug 30, 2009 | 07:07 AM
Bisimoto.com's Avatar
From: Ontario, CA U.S.A. *Dyno Tuning *Performance Parts *Engine Design *Custom Parts
Default Re: Cam gears?
Alot of Road race guys , turbo charged guys, and Off-road sandrail guys use our camgears:
http://bisimoto.net/store/index.php?...dex&cPath=3_93
They are guaranteed not to slip.
We even utilize these gears on our own drag car...
Old Aug 30, 2009 | 07:08 AM
Turbo-LS's Avatar
stock cam gears work just fine if your not building an all out drag car theres really no need to play with cam timing unless your running a massive aftermarket cam
Old Aug 30, 2009 | 07:33 AM
slowboy90's Avatar
i hear nothing but good things from your stuff bisi but im getting real low on funds
Old Aug 30, 2009 | 07:46 AM
SMACKMYPAPA's Avatar
That's not true!
Road Racers use aftermarket camgears to tweak their stock camshafts all the time. Obviously you don't understand what camgears do.
Cam gears works by changing the opening and closing valve events. Which means it can improve power at certain RPM ranges.
Old Aug 30, 2009 | 07:55 AM
slowboy90's Avatar
good explanation we are playing with valve overlap on my car when i get the cam gears in to try to pull some more power out
Old Aug 30, 2009 | 08:07 AM
Ls_dx's Avatar
Originally Posted by SMACKMYPAPA
That's not true!
....Right.. obviously you dont understand that honda cams set straight up with honda cam gears are the best way to go unless you have big cams and a dyno.
Old Aug 30, 2009 | 08:27 AM
slowboy90's Avatar
if your going to run a big cam or are trying to make good power cam gears are a great thing to have and all i asked was has anyone heard about vision but from what i hear Bisimoto offers the best from what i can read so my question is answered ok
Old Aug 30, 2009 | 10:52 AM
Ls_dx's Avatar
No Ive never heard of vision cam gears, and Im running stock cam gears on ITR cams.. so thats what I recommend unless you have a tuner/dyno to fine tune them.
Old Aug 30, 2009 | 07:14 PM
Turbo-LS's Avatar
I understand perfectly what cam gears do. The need to play with cam timing as i mentioned before is not nessesary. If the OP chooses to do so then thats on him. Pulling every last drop of hp by playin with cam timing and overlap etc.. is just not nessesary on an average build thats not an all out race turbo car or all motor track car IMO. thats all i was stating. cam gears also allow you to not only tweak and get more power from your engine by reducing or increasing overlap but they also allow you to shift the powerband of the engine to a certain degree by advancing or retarding the cams can move your powerband up and down in small incruments
I in no way said anything about cam gears not doing anything for a setup, just mearly stated its not nessesary.
OnePointFive
Jan 16, 2008 07:19 AM
ej1252
Nov 10, 2007 05:01 PM
Sir-Boost-Alot
Oct 26, 2005 02:00 PM
sneakychaos
Jun 5, 2002 02:54 PM
