Calibrating AEM UEGO
Old Jul 1, 2004 | 10:33 AM
SSS2000's Avatar
Default Calibrating AEM UEGO
I thought I had my UEGO wideband sensor calibrated, but my EMS was displaying an AFR of 10:1 on my laptop and I was hearing detonation under boost. Before I took the car out, I adjusted the gain to 0.80 so the volts read 4. My timing is retarded .75* per pould of boost. This is in a built LS motor with 9.8:1 JE Flat Top pistons. Should I take out more timing? Or did I calibrate my EMS UEGO wrong?
Thanks,
Tim
Old Jul 1, 2004 | 10:35 AM
Mase's Avatar
Default Re: Calibrating AEM UEGO (MilanoRedLST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRedLST &raquo;</TD></TR><TR><TD CLASS="quote">I thought I had my UEGO wideband sensor calibrated, but my EMS was displaying an AFR of 10:1 on my laptop and I was hearing detonation under boost. Before I took the car out, I adjusted the gain to 0.80 so the volts read 4. My timing is retarded .75* per pould of boost. This is in a built LS motor with 9.8:1 JE Flat Top pistons. Should I take out more timing? Or did I calibrate my EMS UEGO wrong?
Thanks,
Tim</TD></TR></TABLE>
they had specific instructions on the AEM's website, did u follow those?
next, did you calibrate the actual ign timing at the crank pully w/ the aem unit?
u may think ur only running 20 degrees of timing and u may be running like 27
Old Jul 1, 2004 | 10:38 AM
SSS2000's Avatar
Default Re: Calibrating AEM UEGO (Mase)
I followed AEM's instuctions.
Old Jul 1, 2004 | 10:39 AM
Mase's Avatar
do you have any datalogs?
send ur calibration and datalogs to me if u have them.
i'll help u out since u have my beloved aem box
Old Jul 1, 2004 | 10:50 AM
SSS2000's Avatar
OK, Thanks! I'll send you my calibration and some data logs when I get ome from work around 4:30.
Old Jul 1, 2004 | 11:12 AM
legendboy's Avatar
So you have 4.0v at the orange wire with the sensor unpluged??? If you don't, you most likely have a ground problem. What ground are you using for the uego? Sounds like either haven't selected the aem uego from the wizard or you didn't calibrate the voltages using o2#1 gain
Old Jul 1, 2004 | 11:21 AM
SSS2000's Avatar
Default Re: Calibrating AEM UEGO (legendboy)
I'm using the battery as ground, and the aem uego is selected from the wizard.
Old Jul 1, 2004 | 11:22 AM
SSS2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">So you have 4.0v at the orange wire with the sensor unpluged??? If you don't, you most likely have a ground problem. What ground are you using for the uego? Sounds like either haven't selected the aem uego from the wizard or you didn't calibrate the voltages using o2#1 gain</TD></TR></TABLE>
Which part of the sensor needs to be unplugged?
asianspeed
Dec 4, 2007 07:01 PM
93civciv
Dec 4, 2007 05:23 PM
TurboHondaGuy
Nov 9, 2004 05:33 PM
ATS*Mark
May 24, 2004 01:59 PM
SJP0tato
Nov 6, 2003 11:19 PM
