bw s366 numbers
Old Apr 1, 2014 | 01:57 PM
Keo00civic's Avatar
Default bw s366 numbers
Can't find many guys running this turbo. All of the threads are kinda old with info in them. Was wondering Who's made over 700whp with it. I have a s366 but idk if i need to upgrade to a pte 6766 or 6765 to get 700whp. I've seen plenty cars with pte's crack 700 pretty easy.
Old Apr 1, 2014 | 02:24 PM
TheShodan's Avatar
Moderator
Default Re: bw s366 numbers
Ummm.. there's plenty of people running this turbo and have been for almost 10 years. You must not be looking hard enough, or worse yet, you're using BING for your search.
I'll even throw you a bone here if 700whp is what you're worried about.
745whp S366
Done all day. Please use Google this time around and YouTube. You'll find PLENTY of S366 users. You don't need a Precision 67mm to do it.. In fact, the turbine wheel on the Precision is smaller than your S366.
Other Photos.
Good luck.
Old Apr 1, 2014 | 03:15 PM
Keo00civic's Avatar
745whp S366
The Black Civic Coupe - Dyno Tuning - YouTube
Other Photos.
Good luck.
With exception to that video lol. That was one of the only dyno vids that posted numbers tthough. I seen the full race car on the website under the s366 and it mad 7xx in think. Ill use google harder i guess.
Old Apr 1, 2014 | 03:31 PM
Tony the Tiger's Avatar
I tuned a Civic that got close to 700 WHP... It made 674 @ 22 PSI... I had a Supra that make 694 WHP @ 25 PSI and the turbo was pretty much maxed out.
I don't see a B-series can't crack over 700WHP if a Supra managed to get there, assuming the Supras need way more air to make the same power as most typical Hondas.
Old Apr 1, 2014 | 04:12 PM
Keo00civic's Avatar
That's a good number for 22lbs. No way that turbo was maxxed at 22lbs?
Old Apr 1, 2014 | 04:21 PM
AZ_CIVIC's Avatar
I made 715 with a t3/t61mm Garrett turbo, you don't need a 67mm turbo to get there.
Old Apr 1, 2014 | 06:25 PM
Keo00civic's Avatar
The rest of your setup is pretty gangster tthough. Mines isn'tthat bad but idk.
DA 4 Lyfe
Oct 2, 2012 10:20 AM
a1320addict
Feb 21, 2007 08:59 AM
Dark_Helmet
Dec 5, 2006 02:26 PM
DigitalFusion
Apr 30, 2003 09:34 AM
