Butterfly valves in intake
Old Feb 20, 2009 | 01:54 PM
nick6444's Avatar
Default Butterfly valves in intake
Since im building this motor, Is it safe to take ALL the emissions stuff out. Im DDing it, so keep that in mind
Old Feb 20, 2009 | 01:57 PM
RedneckRicer's Avatar
Default Re: Butterfly valves in intake
UH what motor? and why remove the butterflies they were there for a reason. if you do anything you should UPGRADE the intake. removing the butterflies dont add power. they actually help with economy driving and mid range
Old Feb 20, 2009 | 04:23 PM
HiProfile's Avatar
Icon6 Re: Butterfly valves in intake
Define emissions stuff. O2 sensors can be helpful for saving fuel while cruising; PCV has to be should by a catch can (for a few reasons), EGR can be removed but has to be done so properly, same for evap/charcoal system.
The IAB's in b18c1/h22's are benificial overall, the only real gains from not having them is with a different manifold. To see noticable gains keping the stock mani, you must grind out the dividers in addition to removing the butterflies. That essentially makes it a wide-runner manifold with a large plenum, although a properly designed mani will wipe the floor with it.
Old Feb 20, 2009 | 08:23 PM
Scott_Tucker's Avatar
There is very little emissions control equipment on Honda's that will increase power if removed. If it's a daily driver you need a PCV system to keep the oil clean, a breather will not work well.
JPerkMr954
30
Nov 3, 2015 04:34 PM
genuser
Feb 16, 2015 06:03 PM
thunderboy
Jul 19, 2008 06:10 PM
Aeka GSR
Oct 18, 2002 06:58 PM
