BURNING OIL? HELP!!!!!
Old Jul 22, 2007 | 08:55 AM
jrc weez00's Avatar
Default BURNING OIL? HELP!!!!!
i ran a compression test on my b18a1 and they where all 175-180. so i geuss the rings are good. i put a brand new head on it. port polished valves springs retainers. the works. and every once ina while itll sit there and smoke. its white smoke. only running 4psi of boost. all the gaskets are brand new? i was told my valve seals might not of set yet but ive already put a good 300-400 miles on it since the head swap? and ideas. it also smokes during boost which i was told i might wanna get a turbo rebuild kit.
Old Jul 22, 2007 | 10:50 AM
numbnuts22715's Avatar
wheres it smoking from?
Old Jul 22, 2007 | 11:23 AM
jrc weez00's Avatar
the exhaust
Old Jul 22, 2007 | 11:25 AM
RCautoworks's Avatar
Default Re: (jrc weez00)
Do a leak down test, and a wet compression test.
Old Jul 23, 2007 | 09:10 PM
JaredKaragen's Avatar
Default Re: (RCautoworks)
also; if ti is worth a gasket, see if there is more of a buildup on the manifold vs. the downpipe. This could help you narrow it down a little. I have seen a motor that runs clean, the guy thought he blew his rings, it turns out the hot-side seal went out... like 800 miles on the turbo.
coltonbarrier
Aug 29, 2013 02:27 AM
bvillarreal
Jan 24, 2012 02:39 PM
94allmotor
15
Sep 25, 2007 05:31 PM
hondab20t
12
Oct 3, 2006 06:38 PM
Average Al
Jun 28, 2005 10:22 PM
