Built SOHC turbo power numbers
Re: Built SOHC turbo power numbers (jlamaster)
To many factors to say make your question narrower....how built of motor? Power goals? what turbo? and why 1 bar, is that a magical number?? were in America, yur allowed to use psi........I built my bottem end and made 205whp on 6PSI with a T3 60 Trim, so give more info, reasearch, and maybe you will get good info...peace
Re: Built SOHC turbo power numbers (TravSi)
depends on turbo
greddy kit at 1 bar - around 240whp
50 trim t3/t4 at 1 bar - maybe around 300whp
regardless, who cares about how much HP you have. the fastest guys dont always have the most power.
search is your friend
Re: Built SOHC turbo power numbers (FourceFed)
well on my setup with only 8:1 compression i made 343whp at 19psi.
so i would say on the right sized turbo and right compression 350+ is attainable from 1 BAR.
Brian
Brian
i had a stock 1.6 internally and bolted on a turbo kit and made 200whp 167tq and had stock injectors at the time and was only on 6psi i loved it
Re: Built SOHC turbo power numbers (SOHC Gord)
Back from the dead
I just made these numbers.
https://honda-tech.com/zerothread?id=848272
Modified by ELSpool at 7:14 PM 5/6/2004
