built block side to side movement in rods normal
is normal if the rod moves from side to side ( t-belt to tranny side's ) is completly normal , however its not normal when the rod move forward nad backward
that usally happens when it has spun a bearing. I would have it rechecked for clearances and retorque just to make sure,becuase it seems like it has clearance problems. cheack it and good luck.
A spun bearing does not move side to side. The rod will usually move in an up and down motion with a spun bearing. Its normal like I stated before but movement must be very minimal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch »</TD></TR><TR><TD CLASS="quote">block is fresh never used and spings freely</TD></TR></TABLE>
Awesome, you should be good to go. Again the movement is very minimal, correct?
yes they all have the same movement so i assume its part of the clearence prefrences. all have the exact same ammount of movement which is minimual
with clearences correct me if im wrong but dont clearences depends on how the motor is going to be used and how much power it will handle. i think i read loose clearences are for high apps or som ething like that..
