Built block causing a code 23??
Old Jul 12, 2004 | 11:47 AM
ATS*Mark's Avatar
OG triple OG
Default Built block causing a code 23??
hey guys , maybe 2 weeks before my old motor blew up i got a new knock sensor cause the one i had was bad . well i got my new setup all together and its throwing a 23 again . it was fixed but now it seems to be popping up again . i have cp's and pauters can a built block cause this ive herd they are sensitive...
Old Jul 12, 2004 | 11:54 AM
Honsu's Avatar
i believe in hondas it only throws the code if the sensor is bad or the connections are bad. double check all your connections(multimeter is your friend) and u should find the source of your problem
Old Jul 12, 2004 | 02:51 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (Honsu)
ive heard that they are so sensitive that they can throw that knock sensor . has anybody else herd this?
ill check the connections tomorow
Japankid
May 10, 2009 12:42 PM
sir2sol
Apr 1, 2005 04:55 PM
Grip
Jul 13, 2004 08:43 AM
99spanishGT
Mar 26, 2004 12:40 PM
qwklude82
Jan 11, 2003 07:03 PM
